I am trying to write to a list of GPIO pins (nrf52840) and that is impacting the performance as it takes about 500 to 1000usec to write 16 bits (it is bit by bit).
Is there a way to write to a whole port or byte (or a subset) in one go?
DigitalInOut performance
- mikeysklar
Re: DigitalInOut performance
Are you doing this with Arduino or CircuitPython?
- nelfata
I am using CircuitPython, here is a sample:
# turn off all cols
self.gpio.col[0].value = 0
self.gpio.col[1].value = 0
self.gpio.col[2].value = 0
self.gpio.col[3].value = 0
# set rows
self.gpio.row[0].value = (row >> 0 ) & 1
self.gpio.row[1].value = (row >> 1 ) & 1
self.gpio.row[2].value = (row >> 2 ) & 1
self.gpio.row[3].value = (row >> 3 ) & 1
self.gpio.row[4].value = (row >> 4 ) & 1
self.gpio.row[5].value = (row >> 5 ) & 1
self.gpio.row[6].value = (row >> 6 ) & 1
self.gpio.row[7].value = (row >> 7 ) & 1
# set cols
self.gpio.col[0].value = (col ) & 1
self.gpio.col[1].value = (col >> 1) & 1
self.gpio.col[2].value = (col >> 2) & 1
self.gpio.col[3].value = (col >> 3) & 1
- nelfata
Just to be complete:
for i in range(len(Gpio.ROWS)):
self.row[i] = digitalio.DigitalInOut(Gpio.ROWS[i])
self.row[i].direction = digitalio.Direction.OUTPUT
for i in range(0, 4):
self.col[i] = digitalio.DigitalInOut(Gpio.COLS[i])
self.col[i].direction = digitalio.Direction.OUTPUT
- mikeysklar
So you are not using the GPIO library, correct that is just your variable name for the row/col arrays?
Can you post the full code?
- nelfata
I am using the standard DigitalInOut library. I looked into the source code and the nrf port, it seems that there is only bit access API.
- mikeysklar
Looking through the readthedocs it does only look like bit access.
I remember the days where setting by PORT was the norm for Arduino code. It might be worth making a request in the CircuitPython github repo for PORT setting with Digital IO or a faster way to set multiple bits.
https://github.com/adafruit/circuitpython/issues
- nelfata
Thank you for your reply.
Sure I will file a request for this feature. By the way, I ended up writing a C module to improve the performance, and that worked great, but even the C API as provided by NRF (I think) does not have port access, only bit access to the GPIOs.
