Max speed for NEMA 17 Stepper Motor from Adafruit
hoobay
Post by hoobay »
What is the max speed for the NEMA-17 Stepper Motor sold by Adafruit?
The product description said they were able to get it to run at 50RPM.
From a simple project that I tried, I'm seeing about that, I think. I'm new to Arduino and stepper motors in general, so I'm not sure if there is a way to drive it faster.
For my simple project, I take one step which includes going through the 4-step sequence of AINx/BINx. I "delay(1)", and take the next step, and that continues in a loop, and is where I see ~50RPM. If I remove the delay, the motor hums, but does not rotate, so I guess some delay is needed between steps.
So at least with this approach, it does not seem like there is a way to drive the motor faster than 50RPM.
Re: Max speed for NEMA 17 Stepper Motor from Adafruit
That depends partly on the load and partly on the motor driver and power supply you drive it with.
Using the MotorShield V2 and a 12v supply, the max speed without library modifications is about 50 RPM. But the limitation there is communication speed to the Shield.
Driven at 12v with a simple dual H-Bridge driver such as the TB6612 (same as used on the Motor Shield), I've driven these as fast as 250RPM - unloaded. Note that at that speed the motor does not have much torque. If you add some load or try to run faster than 250RPM it will start missing steps.
With a current limiting driver and a higher voltage power supply, it should be possible to increase the torque and achieve higher speeds.
https://learn.adafruit.com/all-about-stepper-motors
