OnDiskBitmap and Transparency
AmazingCircuitPythonFR35
Post by AmazingCircuitPythonFR35 »
I am working on a project using the Raspberry Pico W and a 240x135 screen. I'm reaching the limit of RAM memory.
So I'm trying to reduce the use of RAM especially on images. I replace the method "adafruit_imageload.load(...)" by the method "displayio.OnDiskBitmap(...)".
This works very well. The only problem is that I don't know how to add a transparent color with this method.
I used to use "make_transparent(...)" on the palette, but now I don't know how to do it.
Do you have an example combining "displayio.OnDiskBitmap(...)" and "make_transparent(...)"?
Thanks for your help
Mike
mikeysklar
Re: OnDiskBitmap and Transparency
Post by mikeysklar »
I do see palette.make_transparent(0) being used in the Creating Your First TileMap Game guide.
# make green be transparent so entities can be drawn on top of map tiles
# Create the BANNED TileGrid
BANNED = displayio.TileGrid(
    sprite_sheet,
    pixel_shader=palette,
    width=10,
    height=8,
    tile_width=16,
    tile_height=16,
mikeysklar wrote: Mon Jan 30, 2023 1:50 pm I do see palette.make_transparent(0) being used in the Creating Your First TileMap Game guide.
    sprite_sheet,
    width=10,
    height=8,
    tile_width=16,
    tile_height=16,
Thanks for your answer.
But In this example, the 'make.transparent()' method is associated with the method 'adafruit_imageload.load()'.
I would like to use it with the method 'displayio.OnDiskBitmap()' and I don't see how.
Best regards,
Mike
