Recently received a feather 5303 on order 3002364-4312864653 that is causing power surges on the USB port. The LED's on the board are not coming on. I have tried different workstations and the factory reset using the reset/boot button presses without success.
Jeff B
Defective 5303 Feather
- adafruit_support_carter
Re: Defective 5303 Feather
Is anything attached to the Feather other than the USB cable?
- bicklej
It is new out of the package, no headers, no connectors.
OK, sounds like something on the board might be shorting. Not seeing anything on the LEDs is possible, so may or may not be related.
Can you post photos of both sides of the Feather so we can look for any obvious hardware issue.
How are you getting indications of the power surges?
- bicklej
The power surge is a Windows message - see image of error in attachments.
If have also attached images of the front and back of the board.
- USB Power Surge - 5303.png (35.7 KiB) Viewed 44 times
- IMG_0621.png (731.1 KiB) Viewed 44 times
- IMG_0620.png (522.77 KiB) Viewed 44 times
Thanks. Nothing obvious. Let's just replace it.
Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement PID 5303 Feather.
- bicklej
Thank you for your assistance.
Have a great Day!
Have a great Day!
