Hi all,
I am double clicking the reset button on my Feather M0 but it will not go into Programming Mode. It keeps flashing twice quickly, then pausing, then repeating the pattern. I have 2 boards. Both have the same issue.
I have followed all the basic instructions for using feather m0 with Arduino IDE
https://learn.adafruit.com/adafruit-fea ... rduino-ide
Would anyone be able to help solve this?
Cannot get Feather M0 into Programming Mode
- Curtis5454
- dastels
Re: Cannot get Feather M0 into Programming Mode
Do you see anything in the serial monitor window?
- Curtis5454
Nothing shows up in the serial monitor. I clicked upload, and then double clicked the reset button when it was "waiting for upload port".
This is the output I get
Sketch uses 5308 bytes (2%) of program storage space. Maximum is 262144 bytes.
Performing 1200-bps touch reset on serial port COM4
Waiting for upload port...
No upload port found, using address:"COM4" label:"COM4" protocol:"serial" protocol_label:"Serial Port (USB)" properties:{key:"pid" value:"0xEA60"} properties:{key:"serialNumber" value:"028979CF"} properties:{key:"vid" value:"0x10C4"} as fallback
"C:\Users\curti\AppData\Local\Arduino15\packages\adafruit\tools\bossac\1.8.0-48-gb176eee/bossac.exe" -i -d --port=COM4 -U -i --offset=0x2000 -w -v "C:\Users\curti\AppData\Local\Temp\arduino-sketch-3C4E06EB9A50138B324DFF421DBC6FE1/sketch_jan31a.ino.bin" -R
No device found on COM4
Set binary mode
Send auto-baud
Set binary mode
Failed uploading: uploading error: exit status 1
Set binary mode
Send auto-baud
Set binary mode
- dastels
And it also fails if you don't try to enter bootloader mode manually?
You are certain it should be om COM4?
- Curtis5454
Yes it fails just the same
Yes, there is no COM4 option when I unplug the feather. When I connect to feather #2, COM6 is available instead.
Also to clarify for the post, I have never gotten these boards to program. I tried to program board #2 with arduino without correct Adafruit with Arduino IDE setup. I can't remember if I tried board #1 like this, or if I had setup Arduino correctly before trying to program. Not sure if this would cause issues.
- dastels
Arduino is set up correctly now? BOTH Arduino and Adafruit SAMD board support packages installed?
- Curtis5454
Yes correct. I should have followed all the instructions in that link I attached in my first post. I don't blame you for checking though :)
- dastels
Can you get into bootloader mode without Arduino involved? Connect the board via USB, and double-press reset. FEATHERBOOT should mount.
- Curtis5454
No, that doesn't seem to do anything. Arduino IDE closed, double click reset button, and the red light just keeps flashing 3 times, pause, and repeat.
From a quick google search, it seems that "Featherboot" should show up as a device right next to my C drive, but nothing is there before and after
- dastels
Yes, it mounts as a USB flashdrive.
Have you tried different double-press timing?
Oh! I forgot to ask the mos basic question: are you certain you have a USB data cable, and not a charge/power-only cable?
- Curtis5454
Yes, I have double pressed many times
Yes I have 4 cables that I think are USB data cables and all of them do not solve this problem. Anyways, I would think the double-press would put the feather m0 into programming mode even with just a power connection?
- dastels
Probably not if it can't establish a data connection.
Make sure your cables are data cables.
- adafruit2
can you post a photo of your board please?
- Curtis5454
Attached a photo of the board I'm using
One of the cables I'm using can connect to my kindle, so I think that proves it's not a cable problem
Still nothing working :(
- PXL_20230203_033648466.MP.jpg (378.22 KiB) Viewed 604 times
- dastels
That's not a FeatherM0. It is a Feather 328P https://www.adafruit.com/product/3458. See https://learn.adafruit.com/adafruit-fea ... -ide-setup for Arduino setup.
