EInk time_to_refresh bypass
CR34T0R
Post by CR34T0R »
I'm building a menu displayed on a eInk that is meant to be set up and leave, 2-3 interactions and that's it, but time_to_refresh makes it impossible to do any sort of functional menu interaction. I can wait while epd.busy but there's no way to make any menu with 3 minutes delay for the feedback.
It is a nightmare to debug and test too.
How can I bypass this restriction?
Thank you.
tannewt
Re: EInk time_to_refresh bypass
Post by tannewt »
When you construct the eink driver class pass `seconds_per_frame=<number>`. That's the time `time_to_refresh` is enforcing.
CR34T0R
Post by CR34T0R »
tannewt wrote: Tue Jan 31, 2023 3:14 pm When you construct the eink driver class pass `seconds_per_frame=<number>`. That's the time `time_to_refresh` is enforcing.
Thank you again tannewt, it indeed let's me refresh more often, love it.
Now I have another question, there was a way to wait until refresh was completed right? I'm sure there was a method for this, but I'm unable to find it, do you know what I mean?
Meanwhile I'll just sleep for 1s
tannewt
Post by tannewt »
The display class has a busy attribute that will check the busy pin or wait the specified refresh time. So you can do:
while display.busy:
    pass
CR34T0R
Post by CR34T0R »
tannewt wrote: Mon Feb 06, 2023 1:41 pm The display class has a busy attribute that will check the busy pin or wait the specified refresh time. So you can do:
while display.busy:
    pass
Yes! I was sure I've seen something along those lines but couldn't remember nor find it, thanks!
