So I have been googling on the web for days now without solving my problem, I hope somebody here has seen the issue and could help me out.
I have a Raspberry Pi Pico with adafruit-circuitpython-raspberry_pi_pico-en_GB-7.3.3.uf2.
I try to enable a Adafruit I2C QT Rotary Encoder following the guide on https://learn.adafruit.com/adafruit-i2c ... cuitpython but encounter an error which one the line i2c = board.I2C() which says :
File "<stdin>", line 14, in <module>
AttributeError: 'module' object has no attribute 'I2C'
I have tried with both the Mu Editor and Thonny copy and past back and forth in different ways without any progress. It seems I can't enable the I2C bus and I can't understand what I have missed.
I have tried with only the code below without and success either:
import board
from adafruit_seesaw import seesaw, rotaryio, digitalio
i2c = board.I2C()
I have downloaded the adafruit_seesaw lib into the Pico as well as you can see on the pic.
Circuitpython and I2C challanges
- milhousehouten
- Skärmbild 2023-01-31 124618.png (83.44 KiB) Viewed 77 times
- danhalbert
Re: Circuitpython and I2C challanges
We don't have a `board.I2C()` for Raspberry Pi Pico because there is not a single standard for which pair of pins are the "default" I2C pins on the Pico.
So instead do:
See https://learn.adafruit.com/getting-star ... es-3082902 for more information.
So instead do:
i2c = busio.I2C(board.the_pin_you_want_for_SCL, board.the_pin_you_want_for_SDA)
- milhousehouten
@danhalbert If you only knew how much time I have spent on this issue...
It works as I intended to now. You are a hero!
