ValueError: SCK in use
spatialhacker
Post by spatialhacker »
Environment:
Adafruit CircuitPython 7.3.3 on 2022-08-29; Adafruit Feather ESP32-S2 TFT with ESP32S2
Board ID:adafruit_feather_esp32s2_tft
Running the code or any similar that uses busio.SPI results in
In line 5
"ValueError: SCK in use"
import busio
import digitalio
from board import *
from adafruit_bus_device.spi_device import SPIDevice
with busio.SPI(SCK, MOSI, MISO) as spi_bus:
    cs = digitalio.DigitalInOut(D10)
    device = SPIDevice(spi_bus, cs)
    bytes_read = bytearray(4)
    # The object assigned to spi in the with statements below
    # is the original spi_bus object. We are using the busio.SPI
    # operations busio.SPI.readinto() and busio.SPI.write().
    with device as spi:
        spi.readinto(bytes_read)
    # A second transaction
    with device as spi:
        spi.write(bytes_read)
danhalbert
Re: ValueError: SCK in use
Post by danhalbert »
The display uses the SPI bus, so you can't create a fresh SPI bus that uses the same pins.
But you can share the user of that bus. In your code use
board.SPI()
or
spi = board.SPI()
That will use the already-set-up SPI bus.
