I have the Adafruit Feather M0 Bluefruit LE.
I'm encountering the same issue as these two posts:
viewtopic.php?t=122349
viewtopic.php?f=22&t=155690
I created a Custom Service with a custom UUID as follows in my setup function:
// Add the Custom Service definition
Serial.println(F("Adding Custom Service definition "));
success = ble.sendCommandWithIntReply( F("AT+GATTADDSERVICE=UUID128=dc-5d-81-73-dc-73-4f-11-b0-54-57-14-55-15-b3-b2"), &hrmServiceId);
if (! success) {
error(F("Could not add Custom service"));
@Override
public void onServicesDiscovered(BluetoothGatt gatt, int status) {
if (status == BluetoothGatt.GATT_SUCCESS) {
broadcastUpdate(ACTION_GATT_SERVICES_DISCOVERED);
List<BluetoothGattService> gattServices = getSupportedGattServices();
for (BluetoothGattService gattService : gattServices) {
Log.i(TAG, "Service UUID Found: " + gattService.getUuid().toString());
} else {
Log.w(TAG, "onServicesDiscovered received: " + status);
2023-01-31 18:15:37.677 30616-30678/com.example.android.bluetoothlegatt I/BluetoothLeService: Service UUID Found: 00001800-0000-1000-8000-00805f9b34fb
2023-01-31 18:15:37.678 30616-30678/com.example.android.bluetoothlegatt I/BluetoothLeService: Service UUID Found: 00001801-0000-1000-8000-00805f9b34fb
2023-01-31 18:15:37.678 30616-30678/com.example.android.bluetoothlegatt I/BluetoothLeService: Service UUID Found: 00001530-1212-efde-1523-785feabcd123
2023-01-31 18:15:37.678 30616-30678/com.example.android.bluetoothlegatt I/BluetoothLeService: Service UUID Found: 0000180a-0000-1000-8000-00805f9b34fb
2023-01-31 18:15:37.678 30616-30678/com.example.android.bluetoothlegatt I/BluetoothLeService: Service UUID Found: 6e400001-b5a3-f393-e0a9-e50e24dcca9e
2023-01-31 18:15:37.678 30616-30678/com.example.android.bluetoothlegatt I/BluetoothLeService: Service UUID Found: ee0c2080-8786-40ba-ab96-99b91ac981d8
I've tested it on two separate microcontrollers-- same issue comes up both times.
Any suggestions on what is going on?
