Bluefruit EZ-Link v1.1
jjdeprisco
Post by jjdeprisco »
Is the Bluefruit EZ-Link v1.1 still supported?
Trying to get some example sketches working with this old board from my inventory. Using an Arduino Uno R3. My circuit consists of only the shield plugged into the Arduino.
Adafruit Bluefruit AT Command Example
Initialising the Bluefruit LE module: OK!
Performing a factory reset:
AT+FACTORYRESET
<- Couldn't factory reset
Checked the forum, but didn't see any actual solution to this issue. Also no Youtube videos on the topic.
Using latest library.
Here's my code:
// If you are using the Bluefruit LE Shield then you have an SPI-connected NRF51822 module.
// You can use this with Atmega328 (Arduino UNO or compatible), ATmega32u4 (Arduino Leonardo, compatible) or ATSAMD21
// (Arduino Zero, compatible) and possibly others.
// Your pinouts are Hardware SPI, CS = 8, IRQ = 7, RST = 4
 This is an example for our nRF51822 based Bluefruit LE modules
 Pick one up today in the adafruit shop!
 products from Adafruit!
 MIT license, check LICENSE for more information
 All text above, and the splash screen below must be included in
 any redistribution
#include <Arduino.h>
#include <SPI.h>
#include "Adafruit_BLE.h"
#include "Adafruit_BluefruitLE_SPI.h"
#include "Adafruit_BluefruitLE_UART.h"
#include "BluefruitConfig.h"
#if SOFTWARE_SERIAL_AVAILABLE
  #include <SoftwareSerial.h>
#endif
    APPLICATION SETTINGS
? ? FACTORYRESET_ENABLE? ?  Perform a factory reset when running this sketch
? ?                         Enabling this will put your Bluefruit LE module
                            in a 'known good' state and clear any config
                            data set in previous sketches or projects, so
? ?                         running this at least once is a good idea.
? ?                         When deploying your project, however, you will
                            want to disable factory reset by setting this
                            value to 0.? If you are making changes to your
? ?                         Bluefruit LE device via AT commands, and those
                            changes aren't persisting across resets, this
                            is the reason why.? Factory reset will erase
                            the non-volatile memory where config data is
                            stored, setting it back to factory default
                            values.
? ?                         Some sketches that require you to bond to a
                            central device (HID mouse, keyboard, etc.)
                            won't work at all with this feature enabled
                            since the factory reset will clear all of the
                            bonding data stored on the chip, meaning the
                            central device won't be able to reconnect.
    #define FACTORYRESET_ENABLE      1
// Create the bluefruit object, either software serial...uncomment these lines
//SoftwareSerial bluefruitSS = SoftwareSerial(BLUEFRUIT_SWUART_TXD_PIN, BLUEFRUIT_SWUART_RXD_PIN);
//Adafruit_BluefruitLE_UART ble(bluefruitSS, BLUEFRUIT_UART_MODE_PIN,
//                     BLUEFRUIT_UART_CTS_PIN, BLUEFRUIT_UART_RTS_PIN);
/* ...or hardware serial, which does not need the RTS/CTS pins. Uncomment this line */
// Adafruit_BluefruitLE_UART ble(BLUEFRUIT_HWSERIAL_NAME, BLUEFRUIT_UART_MODE_PIN);
/* ...hardware SPI, using SCK/MOSI/MISO hardware SPI pins and then user selected CS/IRQ/RST */
Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
/* ...software SPI, using SCK/MOSI/MISO user-defined SPI pins and then user selected CS/IRQ/RST */
// Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_SCK, BLUEFRUIT_SPI_MISO,
//                             BLUEFRUIT_SPI_MOSI, BLUEFRUIT_SPI_CS,
//                             BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
// A small helper
void error(const __FlashStringHelper*err) {
  Serial.println(err);
  while (1);
    @brief  Sets up the HW an the BLE module (this function is called
            automatically on startup)
void setup(void)
  while (!Serial);  // required for Flora & Micro
  delay(500);
  Serial.begin(115200);
  Serial.println(F("Adafruit Bluefruit AT Command Example"));
  Serial.println(F("-------------------------------------"));
  /* Initialise the module */
  Serial.print(F("Initialising the Bluefruit LE module: "));
  if ( !ble.begin(VERBOSE_MODE) )
    error(F("Couldn't find Bluefruit, make sure it's in CoMmanD mode & check wiring?"));
  Serial.println( F("OK!") );
  if ( FACTORYRESET_ENABLE )
    /* Perform a factory reset to make sure everything is in a known state */
    Serial.println(F("Performing a factory reset: "));
    if ( ! ble.factoryReset() ){
      error(F("Couldn't factory reset"));
  /* Disable command echo from Bluefruit */
  ble.echo(false);
  Serial.println("Requesting Bluefruit info:");
  /* Print Bluefruit information */
  ble.info();
    @brief  Constantly poll for new command or response data
void loop(void)
  // Display command prompt
  Serial.print(F("AT > "));
  // Check for user input and echo it back if anything was found
  char command[BUFSIZE+1];
  getUserInput(command, BUFSIZE);
  // Send command
  ble.println(command);
  // Check response status
  ble.waitForOK();
    @brief  Checks for user input (via the Serial Monitor)
void getUserInput(char buffer[], uint8_t maxSize)
  memset(buffer, 0, maxSize);
  while( Serial.available() == 0 ) {
    delay(1);
  uint8_t count=0;
  do
    count += Serial.readBytes(buffer+count, maxSize);
    delay(2);
  } while( (count < maxSize) && !(Serial.available() == 0) );
The config file is as follows:
// COMMON SETTINGS
// These settings are used in both SW UART, HW UART and SPI mode
#define BUFSIZE                        160   // Size of the read buffer for incoming data
#define VERBOSE_MODE                   true  // If set to 'true' enables debug output
// SOFTWARE UART SETTINGS
// The following macros declare the pins that will be used for 'SW' serial.
// You should use this option if you are connecting the UART Friend to an UNO
#define BLUEFRUIT_SWUART_RXD_PIN       9    // Required for software serial!
#define BLUEFRUIT_SWUART_TXD_PIN       10   // Required for software serial!
#define BLUEFRUIT_UART_CTS_PIN         11   // Required for software serial!
#define BLUEFRUIT_UART_RTS_PIN         8   // Optional, set to -1 if unused
// RTS is port 8 for UNO UART - JJD
// JJD commented out for testing
// HARDWARE UART SETTINGS
// The following macros declare the HW serial port you are using. Uncomment
// this line if you are connecting the BLE to Leonardo/Micro or Flora
//#ifdef Serial1    // this makes it not complain on compilation if there's no Serial1
//  #define BLUEFRUIT_HWSERIAL_NAME      Serial1
//#endif
// SHARED UART SETTINGS
// The following sets the optional Mode pin, its recommended but not required
#define BLUEFRUIT_UART_MODE_PIN        12    // Set to -1 if unused
// SHARED SPI SETTINGS
// The following macros declare the pins to use for HW and SW SPI communication.
// SCK, MISO and MOSI should be connected to the HW SPI pins on the Uno when
// using HW SPI.  This should be used with nRF51822 based Bluefruit LE modules
// that use SPI (Bluefruit LE SPI Friend).
#define BLUEFRUIT_SPI_CS               8
#define BLUEFRUIT_SPI_IRQ              7
#define BLUEFRUIT_SPI_RST              6    // Optional but recommended, set to -1 if unused, was 4 - JJD
// SOFTWARE SPI SETTINGS
// The following macros declare the pins to use for SW SPI communication.
// This should be used with nRF51822 based Bluefruit LE modules that use SPI
// (Bluefruit LE SPI Friend).
#define BLUEFRUIT_SPI_SCK              13
#define BLUEFRUIT_SPI_MISO             12
#define BLUEFRUIT_SPI_MOSI             11
Return to “Wireless: WiFi and Bluetooth”
