I try to install Adafruit CircuitPython on Jetson Nano with the link: https://learn.adafruit.com/circuitpytho ... GMEALw_wcB
And I found many red texts when updating all your Python 3 packages with the following:
pip3 freeze - local | grep -v '^\-e' | cut -d = -f 1 | xargs -n1 pip3 install -U
I've repeatedly removed the sd card to clean and reinstall the operating system. Help me, please.
thanks, sir.
That image is an issue.
I have a problem when install Adafruit CircuitPython on Jetson Nano
- chimlabs2022
- chimlabs2022
- danhalbert
Re: I have a problem when install Adafruit CircuitPython on Jetson Nano
What version of Python is running on the Jetson Nano? `python --version`
I'm not sure what the stop sign is for: which updates? "apt" updates for Linux, or something else?
- chimlabs2022
I found my python version is 2.7 and fixed it with command
sudo update-alternatives --config python
Thank you very much But still stuck with the stop sign problem.
It says A problem occurred when checking for the updates.
- danhalbert
A "checking for updates" problems sounds like a network connectivity problem. But I really have no idea. This is outside of our experience. The Jetson forum or a similar place might have better advice:
https://forums.developer.nvidia.com/c/a ... on-nano/76
- chimlabs2022
