Mini MQTT too big for Pico W?
fovea1959
Post by fovea1959 »
just got my Pico W. CircuitPython 8.0.0-rc.1.
Tried to use Thonny to load minimqtt into it; ran out of file system space on the Pico. Scratched the lib folder and brought adafruit-circuitpython-bundle-8.x-mpy-20230202.zip down, and tried to populate lib/ from it; too big.
Looks like the Pico only has 0.5m of flash available for the file system (too small to do minimqtt?)
danhalbert
Re: Mini MQTT too big for Pico W?
Post by danhalbert »
adafruit_minimqtt is only about 13kB. Did you just copy over the adafruit_minimqtt folder?
What else is on CIRCUITPY? Did you copy a .UF2 file to it, or are there other large files there for some reason? The UF2 is not needed; it is loaded by the bootloader and does not belong in CIRCUITPY.
You do not need to use Thonny to copy files; you can just drag onto the drive.
If this is on a Mac, make sure there are not a lot of hidden files:
https://learn.adafruit.com/welcome-to-c ... os-3105312
fovea1959
Post by fovea1959 »
I used Thonny to (try to) install it. It decided it needed a ton of dependencies. I then tried to load the entire Adafruit library.
I'll sit down tomorrow with some patience, load Mini MQTT, and load dependencies only as needed.
fovea1959
Post by fovea1959 »
danhalbert wrote: Thu Feb 02, 2023 3:24 pm You do not need to use Thonny to copy files; you can just drag onto the drive.
It's an ESP-EYE, no CIRCUITPY.
danhalbert
Sorry, I'm confused, you said in the first post and the title it was a Pico W. But it's an ESP-EYE board (ESP32)??
fovea1959
Post by fovea1959 »
danhalbert wrote: Thu Feb 02, 2023 11:59 pm Sorry, I'm confused, you said in the first post and the title it was a Pico W. But it's an ESP-EYE board (ESP32)??
no, I'm confused, working two projects at the same time. Yes, it's a Pico W. There is no UF2 on there, but I just let Thonny try to install Mini MQTT (it probably tried to load too many unnecessary "dependencies"), and I didn't try to pick and choose from the adafruit mega-library download. I'll try bringing in just the Mini MQTT from the latter tomorrow, and bring in additional stuff as necessary.
danhalbert
The "circup" tools works out better for automatically installing libraries if CIRCUITPY is available:
https://learn.adafruit.com/keep-your-ci ... ith-circup
