Huzzah32 Webserver crashes after a day or so
- JoshuaDR
I have an esp32 running a websocket server using the async library. The server is rather simple in the fact that it just monitors the status of inputs and some sensors. The webserver works great, everything updates as it should in real-time. However, after a day to a couple of days when I connect to the webserver it is unavailable. When I power cycle the esp32 it goes back to working great with the same ip address. Any thoughts on what would be causing the server to crash?
- dastels
Re: Huzzah32 Webserver crashes after a day or so
What language are you programming in?
- JoshuaDR
I am using Arduino so C++ using the async web server library
- dastels
Are you doing any logging to see what's happening? A memory leak is my first thought.
