NeoPixel Ring-12x5050-Raspberry pi 3
Hayden_P
Post by Hayden_P »
I have recently purchased a NeoPixel Ring - 12 x 5050 RGB LED from amazon.
I have also followed the link https://cdn-learn.adafruit.com/download ... rry-pi.pdf
to install NeoPixel Library.
So, I can turn the LEDS, but they are not acting as desired, for instance, colors are randomly changing/blinking.
So, for the test, I want to turn all the LEDs on and be colored red:
import time
import board
import neopixel
pixel_pin = board.D18
num_pix = 12
order = neopixel.GRBW # won't matter if I use orders, RGB, RGBW, GRB
pixel = neopixel.NeoPixel(pixel_pin, num_pix, brightness = 0.2, auto_write = False, pixel_order = order)
while True:
	pixel.fill((255,0,0))
	pixel.show()
this turn some led with different colors and blinking!
Here is how I connected to my raspberry pi 3 b+ running buster OS.
So if I use the following code, I'm assuming I should get all lights as red, but nothing turns on, and if I put it back under while loop it just blinks for the first few led.
import time
import board
import neopixel
num_pix = 12
pixel.show()
time.sleep(50)
what am I missing, why, few of LED gets change colors, blinking and etc.
This is a frustrating situation, which I spent time to figure it out, and nothing!
adafruit_support_carter
Re: NeoPixel Ring-12x5050-Raspberry pi 3
Are the wire connections to the ring itself soldered?
Hayden_P
Post by Hayden_P »
No they are not, is that make it difference?!
Yes. The wires will need to be soldered to the ring to make a good electrical connection.
Hayden_P
Post by Hayden_P »
I have soldered the wires to the ring, and nothing has changed! I even ordered another ring and the same!
Please post a photo of the soldering.
Hayden_P
Post by Hayden_P »
Here are the pics:
Thanks. Photo is little too low res to make OK soldering well enough to see if it looks good:
Can you post another showing those solder connections better.
And "no change" means the NeoPixel ring still looks like this after running the code in the first post?
Hayden_P
Post by Hayden_P »
yes, the LED flickering weirdly
Screen Shot 2023-02-08 at 1.20.55 PM.png (573.39 KiB) Viewed 60 times
Is the total number of LEDs that flicker the same? And it's always the same number when you run the code?
Soldering looks generally. Maybe a little thin on the GND pad? See here for a general ref:
https://learn.adafruit.com/adafruit-gui ... n-problems
In general, what's being described sounds like a connection issue.
