Hi All,
When I am using color coding with the following example or a variant of this (see partial code below) the matrix show text like half colored. See image.
If I use 888 then have the same result but of course with other colors. Is that expected?
If I use for example 0, 0, 12 then I get normal blue for all text.
Partial code:
matrix.setTextColor(matrix.Color444(12, 0, 5));
matrix.setCursor(0, 0);
matrix.print("This");
matrix.setCursor(5, 6);
matrix.print("is a");
matrix.setCursor(0, 14);
matrix.print("Test");
matrix.setCursor(10, 22);
matrix.setTextWrap(false);
Using Color444 or 888 on 32x32 matrix
- andrew777
- IMG_2371.jpg (690.71 KiB) Viewed 145 times
- blnkjns
Re: Using Color444 or 888 on 32x32 matrix
The change is at the bottom half. So that looks more like a problem with one of the address lines.
What microcontroller do you use, and how is the panel wired?
- andrew777
I am using Arduino mega 2560 rev 3. Pin wiring is as follows:
On Arduino Mega, I have connected R0, G0 and B0 to pins 24, 25 and 26 (RGB Upper). And I have connected R1, G1 and B1 to pins 27, 28 and 29 (RGB Lower).
As described in https://learn.adafruit.com/32x16-32x32-rgb-led-matrix
A, B, C AND D connected to A0, A1, A2, A3
LAT on pin 10, OE on pin 9, CLK on pin 11
GND Connected on three pins.
So in total 16 pins.
- andrew777
Attached a picture to show that blue square is correct and number in white also.
- blnkjns
What library do you use with what bit depth?
Default 16-bit colour would fill the entire MEGA ram space.
With Protomatter library you can run it at say 6 bits per pixel, resulting in a 6kB buffer.
- andrew777
I am using the RGBmatrixPanel lib with 8 bit depth.
- blnkjns
It looks like a memory problem. Try it with the protomatter library instead.
- andrew777
Was off for a couple days. Thanks will try 👍🏻
