I'm new to the Feather/FeatherWing ecosystem and need to confirm my understanding.
I want to use Scorpio to control several strands of of LEDs, but the data is real-time and comes from the internet. Can I use an Adafruit AirLift FeatherWing – ESP32 WiFi Co-Processor PID: 4264 to add WiFi.
Do I attach the Wing right on top of the Scorpio using the appropriate header pins? And all the programming is done on the Scorpio -- which will communicate with the Wing.
Do I have that right? Thanks in advance.
Adding WiFi to RP2040 Scorpio
- mikeysklar
Re: Adding WiFi to RP2040 Scorpio
I don't see any reason why the Feather AirLift ESP32 would cause a conflict. The SPI bus it requires is available.
It would probably be easier to use a Feather doubler with the RP2040 Scorpio so you can access the 8x I/O header easily.
https://www.adafruit.com/product/2890
- dcuccia
Is the DAC on the ESP32 S2 accessible via the AirLift Feather Wing (electrically and via CircuitPython)?
- mikeysklar
No DAC on the ESP32-S2 with CircuitPython.
