I bought this a few years ago but it sat in a drawer since then. I just brought it back out to try on a project, but I can't seem to get into it. I've tried:
* double-tap the reset button - nothing changes, no OS's see it
* hold down the reset button as I plug it in - that actually worked once, but I didn't do anything with it. I never got that back.
Not only do the different OS's not see it, but neither does Thonny or ESP Tool.
The yellow LED flashes very faintly and very quickly. If I plug your 3.7v battery into it, the yellow LED will light up solidly and brightly.
I'll add that I also have a Feather MO Bluefruit LE that I have no issues with. Everything sees it and I can load code on it.
Does 5 LED blinks mean it's smoked?
Huzzah32 WiFI+BY - 5 LED blinks, PC or Mac can't see it
- drrags
- dastels
Re: Huzzah32 WiFI+BY - 5 LED blinks, PC or Mac can't see it
The yellow LED: https://learn.adafruit.com/adafruit-huz ... aq-2431727
What LED is blinking 5 times?
Are you sure it has CircuitPython installed? Does it work with Arduino?
- drrags
Yeah, sorry; the red LED is the one flashing 5 times. The yellow LED detail was added to try to be as complete as I can be.
I assume it has CircuitPython installed, as I've never tried to program it. It doesn't work with anything since it can't be seen by Thonny, Arduino IDE or MU.
- dastels
Can you see REPL output if you connect using a terminal emulator?
- drrags
- dastels
OK, it doesn't sound promising but, alas, you are way out of the replacement window.
- drrags
Yeah, I figured. I just didn't know if there was some kind of undocumented "reset" of some kind. You don't know what you don't know. Thanks :-)
