Arduino Yun PoE module
- aud1073ch
I have a couple of the older Arduino Yun boards, that have the vias to install a PoE module. Will the modules sold by Adafruit fit the Yun boards?
Re: Arduino Yun PoE module
I honestly don't know.
What's the distance between the two innermost pins for the PoE connection on your Yun?
- aud1073ch
The spacing if the pins near the center gap is 1.2 inches pin center to pin center. Pin spacing is 0.1 inches. 4pins on one side, 6 pins on the other side. Spacing between outside pins is 2 in.
That sounds like it should match the pin spacing of this one:
https://www.adafruit.com/product/3848
It would probably be a good idea to check the actual pin connections in the Arduino forum:
https://forum.arduino.cc/
The Yun documentation doesn't seem to say anything about the PoE headers or pinout.
