PyGamer power question
Claude_J_Greengrass
Post by Claude_J_Greengrass »
I have PyGamer driving a couple of 3.5v relays. They work correctly in that they switch on and off when the USB cable is not connecting the PyGamer to my PC. When I connect the USB cable, the LEDs on the relay module continue to flash, but the relays do not operate.
Any suggestions to resolve this problem?
I should add, I have a Lithium Ion Polymer Battery - 3.7V 350mAh attached at the same time as the USB cable
dastels
Re: PyGamer power question
Post by dastels »
How are the relays wired? And what are the relays? Pictures of components and connections generally help.
Claude_J_Greengrass
Hi Dave,
The relay in question can be found here: https://www.amazon.com/gp/product/B07QG ... UTF8&psc=1
dastels
Post by dastels »
That's what they are. What about the rest of my questions?
Claude_J_Greengrass
Here is the wiring. I used Adafruit QT cables
PyGamer Relay Wiiring.JPG (576.81 KiB) Viewed 201 times
dastels
Post by dastels »
Those are just 3-pin JST connectors, not STEMMA, and certainly not QT.
Are you sure that the Vcc on those JST connections is 3.3v and not 5v which I believe is the default. See https://learn.adafruit.com/adafruit-pyg ... ep-3028887.
Claude_J_Greengrass
Wow! I completely missed that. It makes life much easier. I can use SSRs for switching.
May thanks for making me re-read the specification.
Return to “Other Arduino products from Adafruit”
