I am trying to connect one of the green Seesaw soil moisture/temprature probes to a Fun House board. This project has several sensors and all of them connect just fine except the Seesaw. Here is the code I'm using to try to set up the connection:
#Create the Sparkfun MUX (TCA9548A) object and give it the I2C bus
tca = adafruit_tca9548a.TCA9548A(i2c)
# for each sensor, create it using the TCA9548a channel instead of the I2C object
ambient = adafruit_mcp9808.MCP9808(tca[0]) # ambient.temperature
bottom = adafruit_mcp9808.MCP9808(tca[4]) # bottom.temperature
mid = adafruit_mcp9808.MCP9808(tca[5]) # mid.temperature
co2 = adafruit_scd4x.SCD4X(tca[1]) # co2.CO2; co2.temperature; co2.relative_humidity
light = adafruit_bh1750.BH1750(tca[7]) # light.lux
h2o = Seesaw(tca[6]) # h2o.moisture_read; h2o.get_temp
When I run this code, it crashes because "there is no I2C device at address: 0x49"
What am I doing wrong?
Connecting a Seesaw soil probe through a TCA9548a
- CapeZinFan
- CapeZinFan
Re: Connecting a Seesaw soil probe through a TCA9548a
I should also have said, this code runs fine if I comment out the line which attempts to create the Seesaw link.
- mrrmay
Hmm… seems like seen this before with another device.
Have you,
- checked the other I2C addresses?
- checked the wire connection?
I also fried a BME280 and got this response.
Have you,
- adafruit_support_carter
The soil sensor has an I2C address of 0x36, which must be specified when setting up the soil sensor. See example code in guide:
https://learn.adafruit.com/adafruit-ste ... ge-3009830
For your code, change this line:
to:
h2o = Seesaw(tca[6], addr=0x36) # h2o.moisture_read; h2o.get_temp
- CapeZinFan
Thank you! That did solve my problem. Now, to be sure I understand why the Seesaw module operates different from all(?)/most(?) Adafruit modules is that the Adafruit modules imbed the i2c address in their definition (which they can do because each module is board specific, or nearly so) and the Seesaw module actually covers several different sensors and boards, so can't do that. Is that sort of correct?
That's generally correct. However, even the other non-seesaw boards may have different I2C addresses. As much as possible, libraries are written to work with the default address the board ships with. That way, no additional parameters are needed to use the board "out of the box". But if an alternate address is set, then it would need to be specified in a similar manner in the code.
The PCA9685 is a good example of this:
https://learn.adafruit.com/16-channel-p ... rds-848847
It has over 60 settable addresses!
The info here may also help:
https://learn.adafruit.com/working-with ... 2c-devices
