Support for ESP32-S3-DevKitC-1-N32R8
For Adafruit customers who seek help with microcontrollers
adafruit_support_carter
Re: Support for ESP32-S3-DevKitC-1-N32R8
Make sure the builtin define is actually mapping to GPIO38.
https://docs.espressif.com/projects/esp ... itc-1.html
Addressable RGB LED, driven by GPIO38.
It's not a regular LED driven by digital HIGH/LOW or PWM. So also make sure you're running something that's talking to the LED correctly. Like NeoPixel library, etc.
Also, possibly some variance with hardware revisions? (from same espressif page linked above)
QnBarb
Post by QnBarb »
It works!!!! It's so beautifulllll!!!! :)Thank you so much.
QnBarb
Post by QnBarb »
Here is the setting that works for this board (for me):
ESP32-S3DEVKITC-1-N32R8V (32MB):
USB CDC On Boot: Enabled
CPU Frequency: 240MHz (WiFi)
Core Debug Level: None
USB DFU On Boot: Disabled
Erase All Flash Before Sketch Upload: Disabled
Events Run On: Core 1
Flash Mode: DIO 80MHz
Flash Size: 4MB (32Mb)
JTAG Adapter: Integrated USB JTAG
Arduino Runs On: Core 1
USB Firmware MSC On Boot: Disabled
Partition Scheme: Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS)
PSRAM: OPI PSRAM
Upload Mode: UART0/Hardware CDC
Upload Speed: 921600
USB Mode: Hardware CDC/JTAG
sjxuereb
Post by sjxuereb »
Hi
Board: Espressif ESP32­-S3­-DevKitC-1-N32R8V, ESP32-S3-WROOM-2, 8MB PSRAM, 32MB
IDE Arduino 2.0.3 - ESP32S3 Dev Module
I have the managed to get to this point using the settings mentioned in this thread:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x18 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
Octal Flash Mode Enabled
For OPI Flash, Use Default Flash Boot Mode
mode:SLOW_RD, clock div:1
load:0x3fce3808,len:0x3ac
load:0x403c9700,len:0x9bc
load:0x403cc700,len:0x27c0
entry 0x403c98c0
However I am uploading a serial sketch[as below] and I am only getting the above output in the serial monitor. has my sketch uploaded ? Why am I not getting hello world ? My board is connected on the usb-uart & when I press reset button I get only the above. Thanks
Serial.begin(115200);
Serial.println("Hello World!");
QnBarb
Post by QnBarb »
It seems your board is working. Are you connected to the USB or the UART?
It works with the USB port for me (your code).
It doesn't work with the UART port for me. I think you have to install a driver. I do not know how.
Hope this helps. Sorry for responding so late.
QnBarb
Post by QnBarb »
Also, you might have to hit reset button after upload.
slight
Post by slight »
@QnBarb, are you willing to share a minimal test-sketch for the neopixel rgb led?
with your settings my sketches compile.
but my led is still off...
sjxuereb
Post by sjxuereb »
Settings that worked .... in screenshots
Return to “Microcontrollers”
