I cannot get my QT Py ESP32-C3 WiFi board to connect to WiFi using the following:
WiFi.begin(ssid, password);
Serial.print("\nConnecting to WiFi");
Serial.println(wifi_status);
while(WiFi.status() != WL_CONNECTED){
Serial.print(".");
delay(1000);
I am able to connect to WiFi using other ESP32 boards.
Does this indicate a faulty board?
QT Py ESP32-C3 won't connect to WiFi
- mikeysklar
Re: QT Py ESP32-C3 won't connect to WiFi
Just to confirm you are using this example code with your username and YOUR_SSID* fields customized?
https://learn.adafruit.com/adafruit-qt- ... st-3077319
If the above is not working are you able to run the WiFi Scan?
// SPDX-FileCopyrightText: 2020 Brent Rubell for Adafruit Industries
// SPDX-License-Identifier: MIT
Web client
This sketch connects to a website (wifitest.adafruit.com/testwifi/index.html)
using the WiFi module.
This example is written for a network using WPA encryption. For
WEP or WPA, change the Wifi.begin() call accordingly.
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe
#include <WiFi.h>
// Enter your WiFi SSID and password
char ssid[] = "YOUR_SSID"; // your network SSID (name)
char pass[] = "YOUR_SSID_PASSWORD"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "wifitest.adafruit.com"; // name address for adafruit test
char path[] = "/testwifi/index.html";
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
//Initialize serial and wait for port to open:
Serial.begin(115200);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// attempt to connect to Wifi network:
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("Connected to WiFi");
printWifiStatus();
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected to server");
// Make a HTTP request:
client.print("GET "); client.print(path); client.println(" HTTP/1.1");
client.print("Host: "); client.println(server);
client.println("Connection: close");
client.println();
// if there are incoming bytes available
// from the server, read them and print them:
while (client.available()) {
char c = client.read();
Serial.write(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println();
Serial.println("disconnecting from server.");
client.stop();
// do nothing forevermore:
while (true) {
delay(100);
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Load up the WiFiScan example under Examples->Examples for YOUR BOARDNAME->WiFi->WiFiScan
- ajscam
Yes, I have tried the example at the link with correct SSID & PASSW.
Interestingly, Wifi Scanner does find all my available networks.
I tried 2 different SSIDs with no success.
13:08:27.749 -> Nr | SSID | RSSI | CH | Encryption
13:08:27.749 -> 1 | A | -51 | 6 | WPA2+WPA3
13:08:27.788 -> 2 | B | -51 | 6 | WPA2
