Itsy Bitsy low power mode.
troste
Post by troste »
I got a itsy bitsy product number 4481 and SHT31 product number 2857
Which low power states does it support?
How do you enter this states?
I want to measure and log to a file in the flash each 15 minuttes.
Running on a battery I want to use as little energy as possible.
At the moment I am at 2.5 mA using delay in the main loop.
#include <Arduino.h>
#include <Wire.h>
#include <SdFat.h>
#include <RTClib.h>
#include <Adafruit_SPIFlash.h>
#include <Adafruit_SHT31.h>
#include "flash_config.h"
Adafruit_SPIFlash flash(&flashTransport);
Adafruit_SHT31 sht31 = Adafruit_SHT31();
FatVolume fatfs;
RTC_Millis rtc;
#define FILE_NAME "Fre01.dat"
#define useSerial 0
uint8_t freId = 1;                                 // Id number;
unsigned long loopTime = 15*60*1000;  // Looptime in milliseconds
bool useTemp = true;
DateTime nowTime;
DateTime startTime;
void readWriteTempHumid() {
  uint8_t temp = 110;
  uint8_t humid = 120;
  if (useTemp)
    if (! sht31.begin(0x44)) {
#ifdef useSerial
        Serial.println("Couldn't find SHT31");
#endif
      while (1) delay(1);
    temp  = round(sht31.readTemperature());
    humid = round(sht31.readHumidity());
    sht31.reset();
#ifdef useSerial
   nowTime = rtc.now();
   char buf[] = "YYMMDD-hh:mm:ss";
   Serial.print("Time ");
   Serial.print(nowTime.toString(buf));
   Serial.print("  ");
   Serial.print("Temp *C = ");
   Serial.print(temp);
   Serial.print("  ");
   Serial.print("Humid. % = ");
   Serial.println(humid);
#endif
  File32 dataFile = fatfs.open(FILE_NAME, FILE_WRITE);
  dataFile.print(temp);
  dataFile.print(",");
  dataFile.println(humid);
  dataFile.close();
void initSerial() {
#ifdef useSerial
  Serial.begin(115200);             // Open serial communications.
  while (!Serial) {delay(10); }     // wait for serial port to connect. Needed for native USB port only
  Serial.println("Serial is running.");
#endif
void initFlash() {
  flash.begin();                    // Init external flash
  if ( !fatfs.begin(&flash) ) {     // Open file system on the flash
#ifdef useSerial
         Serial.println("Error: filesystem is not existed. Please try SdFat_format example to make one.");
#endif
    while(1)
      yield();
      delay(1);
#ifdef useSerial
    Serial.println("Filesystem is running.");
#endif
void initClock() {
  startTime = DateTime(F(__DATE__), F(__TIME__));
  rtc.adjust(startTime);
void initFile() {
  dataFile.print("Id  nummer : " );
  dataFile.println(freId);
  dataFile.print ("Start tid : ");
  dataFile.println(startTime.toString(buf));
  dataFile.print ("Loop tid i minutter : ");
  dataFile.println(loopTime/60000);
  dataFile.close();
  initSerial();
  initFlash();
  initClock();
  initFile();
  readWriteTempHumid();
  delay(loopTime);
mikeysklar
Re: Itsy Bitsy low power mode.
Post by mikeysklar »
Checkout SystemOff() and WaitForEvent().
https://github.com/adafruit/Adafruit_nR ... ing.c#L102
There is also the low power timer breakout to consider TLP5110.
https://www.adafruit.com/product/3435
troste
Post by troste »
Thank you.
I think WaitForEvent() is the way to go.
How do I set an event using the internal clock millis?
mikeysklar
Before getting into WaitForEvent(), try using delay() with your 15 minute (900 second) wait period.
delay(900000);
The delay() code should also call WaitForEvent() on it’s own (put the processor into low power mode) so you don’t have to setup any callbacks for event triggers.
Some more examples and info for WaitForEvent() should you go that route.
viewtopic.php?t=128823&start=60
https://github.com/adafruit/Adafruit_nR ... itforevent
troste
Post by troste »
So I am already using this low power state in my program above?
loopTime is 15*60*1000 = 900 000 millis.
languer
Post by languer »
You may want to check out "ArduinoLowPower.h". That library appears to work with SAMD, NRF52 architectures.
mikeysklar
2.5mA is still really high.
What do you see as a baseline current draw with your hardware connected, but just running this:
	suspendLoop();
If you really want to maximize battery consider the TLP5110. It is kind of a hack to cut power to everything, but it will get you down to 15nA.
troste
Post by troste »
With just the itsy bitsy I am down to 0.90 mA.
Using this code.
suspendLoop();
mikeysklar
You can see how far you get with the ArduinoLowPower.h that @languer mentioned. I’ve not tried that one.
Otherwise the TLP5110 makes a lot more sense if the controller is going to draw near 1mA in idle mode.
Return to “Itsy Bitsy Boards”
