Hello everybody,
Sorry if this newbie question has already been adressed somewhere in this forum.
Slight confusion here: on the PCB of Adafruit's 1.2 kit (blue version), the "EBC" marking next to the 4 PN2222A locations suggests that emitter pins are connected to the cathodes of the 4 IR LEDs. In the official schematic (tvbgone3sch.png) however, PN2222A collectors are (with emitters connected to ground).
All reproductions I have been making with various LED models (including the fantastic Osram SFH4544), connecting collectors to cathodes, work very well.
Just to remove any ambiguity about the PN2907A + 4 PN2222A combo, can anyone definitely confirm that NPN transistors' collector pins should connect to LEDs cathodes, emitter pins to ground, as shown in the schematic?
Thanks a lot!
Emitter / Collector pins proper connection in the 1.2 kit
- madlynxx
- dastels
Re: Emitter / Collector pins proper connection in the 1.2 kit
Yes, with an NPN transistor the collector connects to the LED cathode, emitter to ground That lets the transistor switch current flow through the LED on/off.
Why do the PCB markings suggest that the emitters are connected to the cathodes?
- madlynxx
Thank you Dave for you answer.
About the "EBC" marking in the picture above, possibly a misreading on my part (as it's possibly not meant to indicate the PN2222A mounting orientation). Associated with the transistor TO-92 shape marking next to it, it suggests that the provided PN2222A have a "CBE" pinout, which is not very common, hence my question.
I may push the interpretation a little to far :)
Anyway, thanks for the collector / cathode connection confirmation!
- dastels
OK. Yeah, that is odd. It should be CBE if it's referring to the transistor pins. Even so it's completely unnecessary since the outline is there.
