magtag can't connect to wifi from more than 20' away
lwhitehorn
Post by lwhitehorn »
I have a new (black mask) magtag that can't connect to a wifi AP if it's more than about 15-20' feet away. It connects fine if it's really, really, really close, but otherwise, nada. Every other device in the house, including other ESP32 devices, can connect to this AP.
Doesn't seem to be channel-related. Is there some configuration setting to get the ESP32 to connect from a normal distance?
Some forums have mentioned disabling wifi sleep, but I'm new to CircuitPython and don't know how to go about doing that.
mikeysklar
Re: magtag can't connect to wifi from more than 20' away
Post by mikeysklar »
Have you run the WiFi test that shows RSSI values? It might be helpful to how the signal strength chases with orientation at different distances from the access point.
https://learn.adafruit.com/adafruit-mag ... et-connect
There is also a wifi.Radio.tx_power setting you can use to increase transmit power.
https://docs.circuitpython.org/en/lates ... o.tx_power
https://github.com/adafruit/circuitpython/issues/6559
lwhitehorn
Thanks. Still seems like a distance problem in the sense that once there's anything, e.g. wall between the MagTag and the AP, it can't connect.
Return to “Wireless: WiFi and Bluetooth”
