Strange errors involving example
AndrewElectronics
Post by AndrewElectronics »
Hello all!
I used the following example code on my CLUE: (I deleted the SPI Flash part, because it didn't work)
#include <Adafruit_Arcada.h>
#include <Adafruit_SPIFlash.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_LSM6DS33.h>
#include <Adafruit_LIS3MDL.h>
#include <Adafruit_SHT31.h>
#include <Adafruit_APDS9960.h>
#include <Adafruit_BMP280.h>
#include <PDM.h>
#define WHITE_LED 43
Adafruit_Arcada arcada;
Adafruit_LSM6DS33 lsm6ds33;
Adafruit_LIS3MDL lis3mdl;
Adafruit_SHT31 sht30;
Adafruit_APDS9960 apds9960;
Adafruit_BMP280 bmp280;
extern PDMClass PDM;
extern Adafruit_FlashTransport_QSPI flashTransport;
uint32_t buttons, last_buttons;
uint8_t j = 0;  // neopixel counter for rainbow
// Check the timer callback, this function is called every millisecond!
volatile uint16_t milliseconds = 0;
void timercallback() {
  analogWrite(LED_BUILTIN, milliseconds);  // pulse the LED
  if (milliseconds == 0) {
    milliseconds = 255;
  } else {
    milliseconds--;
  Serial.begin(115200);
  // enable NFC pins
  if ((NRF_UICR->NFCPINS & UICR_NFCPINS_PROTECT_Msk) == (UICR_NFCPINS_PROTECT_NFC << UICR_NFCPINS_PROTECT_Pos)){
    Serial.println("Fix NFC pins");
    NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;
    while (NRF_NVMC->READY == NVMC_READY_READY_Busy);
    NRF_UICR->NFCPINS &= ~UICR_NFCPINS_PROTECT_Msk;
    NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
    Serial.println("Done");
    NVIC_SystemReset();
  pinMode(WHITE_LED, OUTPUT);
  digitalWrite(WHITE_LED, LOW);
  Serial.println("Hello! Arcada Clue test");
  if (!arcada.arcadaBegin()) {
    Serial.print("Failed to begin");
    while (1);
  arcada.displayBegin();
  Serial.println("Arcada display begin");
  for (int i=0; i<250; i+=10) {
    arcada.setBacklight(i);
    delay(1);
  arcada.display->setCursor(0, 0);
  arcada.display->setTextWrap(true);
  arcada.display->setTextSize(2);
  /********** Check MIC */
  PDM.onReceive(onPDMdata);
  if (!PDM.begin(1, 16000)) {
    Serial.println("**Failed to start PDM!");
   /********** Check filesystem next */
  if (!arcada.filesysBegin()) {
    Serial.println("Failed to load filesys");
    arcada.display->setTextColor(ARCADA_YELLOW);
    arcada.display->println("Filesystem not found");
  } else {
    Serial.println("Filesys OK!");
    arcada.display->setTextColor(ARCADA_GREEN);
    arcada.display->println("Filesystem OK");
  arcada.display->setTextColor(ARCADA_WHITE);
  arcada.display->println("Sensors Found: ");
  /********** Check APDS */
  if (!apds9960.begin()) {
    Serial.println("No APDS9960 found");
    arcada.display->setTextColor(ARCADA_RED);
  } else {
    Serial.println("**APDS9960 OK!");
    apds9960.enableColor(true);
  arcada.display->print("APDS9960 ");
  /********** Check LSM6DS33 */
  if (!lsm6ds33.begin_I2C()) {
    Serial.println("No LSM6DS33 found");
  } else {
    Serial.println("**LSM6DS33 OK!");
  arcada.display->println("LSM6DS33 ");
  /********** Check LIS3MDL */
  if (!lis3mdl.begin_I2C()) {
    Serial.println("No LIS3MDL found");
  } else {
    Serial.println("**LIS3MDL OK!");
  arcada.display->print("LIS3MDL ");
  /********** Check SHT3x */
  if (!sht30.begin(0x44)) {
    Serial.println("No SHT30 found");
  } else {
    Serial.println("**SHT30 OK!");
  arcada.display->print("SHT30 ");
  /********** Check BMP280 */
  if (!bmp280.begin()) {
    Serial.println("No BMP280 found");
  } else {
    Serial.println("**BMP280 OK!");
  arcada.display->println("BMP280");
  buttons = last_buttons = 0;
  arcada.timerCallback(1000, timercallback);
  arcada.display->setTextWrap(false);
  arcada.display->setTextColor(ARCADA_WHITE, ARCADA_BLACK);
  arcada.display->setCursor(0, 100);
  arcada.display->print("Temp: ");
  arcada.display->print(bmp280.readTemperature());
  arcada.display->print(" C");
  arcada.display->println("         ");
  arcada.display->print("Baro: ");
  arcada.display->print(bmp280.readPressure()/100);
  arcada.display->print(" hPa");
  arcada.display->print("Humid: ");
  arcada.display->print(sht30.readHumidity());
  arcada.display->print(" %");
  uint16_t r, g, b, c;
  //wait for color data to be ready
  while(! apds9960.colorDataReady()) {
    delay(5);
  apds9960.getColorData(&r, &g, &b, &c);
  arcada.display->print("Light: ");
  arcada.display->print(c);
  sensors_event_t accel, gyro, mag, temp;
  lsm6ds33.getEvent(&accel, &gyro, &temp);
  lis3mdl.getEvent(&mag);
  arcada.display->print("Accel:");
  arcada.display->print(accel.acceleration.x, 1);
  arcada.display->print(",");
  arcada.display->print(accel.acceleration.y, 1);
  arcada.display->print(accel.acceleration.z, 1);
  arcada.display->print("Gyro:");
  arcada.display->print(gyro.gyro.x, 1);
  arcada.display->print(gyro.gyro.y, 1);
  arcada.display->print(gyro.gyro.z, 1);
  arcada.display->print("Mag:");
  arcada.display->print(mag.magnetic.x, 1);
  arcada.display->print(mag.magnetic.y, 1);
  arcada.display->print(mag.magnetic.z, 1);
  uint32_t pdm_vol = getPDMwave(256);
  Serial.print("PDM volume: "); Serial.println(pdm_vol);
  arcada.display->print("Mic: ");
  arcada.display->print(pdm_vol);
  Serial.printf("Drawing %d NeoPixels\n", arcada.pixels.numPixels());
  for(int32_t i=0; i< arcada.pixels.numPixels(); i++) {
     arcada.pixels.setPixelColor(i, Wheel(((i * 256 / arcada.pixels.numPixels()) + j*5) & 255));
  arcada.pixels.show();
  j++;
  uint8_t pressed_buttons = arcada.readButtons();
  if (pressed_buttons & ARCADA_BUTTONMASK_A) {
    Serial.println("BUTTON A");
    tone(ARCADA_AUDIO_OUT, 4000, 100);
  } else {
    tone(ARCADA_AUDIO_OUT, 0);
  if (pressed_buttons & ARCADA_BUTTONMASK_B) {
    Serial.println("BUTTON B");
    digitalWrite(WHITE_LED, HIGH);
  } else {
  last_buttons = buttons;
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return arcada.pixels.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return arcada.pixels.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
   WheelPos -= 170;
   return arcada.pixels.Color(0, WheelPos * 3, 255 - WheelPos * 3);
int16_t minwave, maxwave;
short sampleBuffer[256];// buffer to read samples into, each sample is 16-bits
volatile int samplesRead;// number of samples read
int32_t getPDMwave(int32_t samples) {
  minwave = 30000;
  maxwave = -30000;
  while (samples > 0) {
    if (!samplesRead) {
      yield();
      continue;
    for (int i = 0; i < samplesRead; i++) {
      minwave = min(sampleBuffer[i], minwave);
      maxwave = max(sampleBuffer[i], maxwave);
      //Serial.println(sampleBuffer[i]);
      samples--;
    // clear the read count
    samplesRead = 0;
  return maxwave-minwave;
void onPDMdata() {
  // query the number of bytes available
  int bytesAvailable = PDM.available();
  // read into the sample buffer
  PDM.read(sampleBuffer, bytesAvailable);
  // 16-bit, 2 bytes per sample
  samplesRead = bytesAvailable / 2;
Here are the strange internal error codes:
In file included from D:\Arduino\libraries\Adafruit_TinyUSB_Library\src/Adafruit_TinyUSB.h:46,
from D:\Arduino\libraries\Adafruit_NeoPixel/Adafruit_NeoPixel.h:48,
from D:\Arduino\libraries\Adafruit_Arcada_Library/Adafruit_Arcada.h:10,
from D:\Arduino\sketch_feb15a\sketch_feb15a.ino:1:
D:\Arduino\libraries\Adafruit_TinyUSB_Library\src/arduino/hid/Adafruit_USBD_HID.h:42:40: error: 'HID_ITF_PROTOCOL_NONE' was not declared in this scope; did you mean 'HID_PROTOCOL_NONE'?
42 | uint8_t protocol = HID_ITF_PROTOCOL_NONE,
| HID_PROTOCOL_NONE
In file included from D:\Arduino\libraries\Adafruit_ImageReader_Library/Adafruit_ImageReader.h:18,
from D:\Arduino\libraries\Adafruit_Arcada_Library/arcadatype.h:5,
from D:\Arduino\libraries\Adafruit_Arcada_Library/Boards/Adafruit_Arcada_Clue.h:21,
from D:\Arduino\libraries\Adafruit_Arcada_Library/Adafruit_Arcada.h:21,
D:\Arduino\libraries\Adafruit_SPIFlash\src/Adafruit_SPIFlash.h:55:8: error: conflicting return type specified for 'virtual bool Adafruit_SPIFlash::end()'
55 | bool end(void);
In file included from D:\Arduino\libraries\SdFat_-_Adafruit_Fork\src/SdCard/SdCardInterface.h:27,
from D:\Arduino\libraries\SdFat_-_Adafruit_Fork\src/SdCard/SdioCard.h:28,
from D:\Arduino\libraries\SdFat_-_Adafruit_Fork\src/SdCard/SdCard.h:27,
from D:\Arduino\libraries\SdFat_-_Adafruit_Fork\src/SdFat.h:32,
from D:\Arduino\libraries\Adafruit_SPIFlash\src/Adafruit_SPIFlash.h:32,
d:\arduino\libraries\sdfat_-_adafruit_fork\src\common\fsblockdeviceinterface.h:42:16: note: overridden function is 'virtual void FsBlockDeviceInterface::end()'
42 | virtual void end() {}
Using library Adafruit_Arcada_Library at version 2.5.4 in folder: D:\Arduino\libraries\Adafruit_Arcada_Library
Using library Adafruit_GFX_Library at version 1.11.5 in folder: D:\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_BusIO at version 1.8.2 in folder: D:\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: D:\ArduinoData\packages\adafruit\hardware\nrf52\0.21.0\libraries\Wire
Using library SPI at version 1.0 in folder: D:\ArduinoData\packages\adafruit\hardware\nrf52\0.21.0\libraries\SPI
Using library Adafruit_NeoPixel at version 1.11.0 in folder: D:\Arduino\libraries\Adafruit_NeoPixel
Using library Adafruit_TinyUSB_Library at version 1.18.1 in folder: D:\Arduino\libraries\Adafruit_TinyUSB_Library
Using library Adafruit_TouchScreen at version 1.1.3 in folder: D:\Arduino\libraries\Adafruit_TouchScreen
Using library Adafruit_LSM6DS at version 4.6.0 in folder: D:\Arduino\libraries\Adafruit_LSM6DS
Using library Adafruit_Unified_Sensor at version 1.1.4 in folder: D:\Arduino\libraries\Adafruit_Unified_Sensor
Using library Adafruit_ST7735_and_ST7789_Library at version 1.10.0 in folder: D:\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library
Using library Adafruit_ImageReader_Library at version 2.8.1 in folder: D:\Arduino\libraries\Adafruit_ImageReader_Library
Using library Adafruit_SPIFlash at version 3.11.0 in folder: D:\Arduino\libraries\Adafruit_SPIFlash
Using library SdFat_-_Adafruit_Fork at version 2.2.1 in folder: D:\Arduino\libraries\SdFat_-_Adafruit_Fork
Using library Adafruit_WavePlayer_Library at version 1.0.3 in folder: D:\Arduino\libraries\Adafruit_WavePlayer_Library
Using library ArduinoJson at version 6.20.0 in folder: D:\Arduino\libraries\ArduinoJson
Using library Adafruit_LIS3MDL at version 1.2.1 in folder: D:\Arduino\libraries\Adafruit_LIS3MDL
Using library Adafruit_SHT31_Library at version 2.2.0 in folder: D:\Arduino\libraries\Adafruit_SHT31_Library
Using library Adafruit_APDS9960_Library at version 1.2.2 in folder: D:\Arduino\libraries\Adafruit_APDS9960_Library
Using library Adafruit_BMP280_Library at version 2.6.5 in folder: D:\Arduino\libraries\Adafruit_BMP280_Library
Using library PDM at version 1.0 in folder: D:\ArduinoData\packages\adafruit\hardware\nrf52\0.21.0\libraries\PDM
Using library Adafruit_EPD at version 4.5.1 in folder: D:\Arduino\libraries\Adafruit_EPD
exit status 1
Error compiling for board Adafruit CLUE.
I went through all the libraries listed in your tutorial guide (https://learn.adafruit.com/adafruit-clue) individually, and updated each one. It still didn't work.
Thank you so much in advance!
Andrew.
Last edited by adafruit_support_carter on Wed Feb 15, 2023 3:59 pm, edited 1 time in total.
Reason: change to [code] tags
dastels
Re: Strange errors involving example
Post by dastels »
First, make sure everything is up to date, not just the the ones listed. There could be dependencies. Same for board support packages.
Just did a test compile here with above sketch and had no errors. So something with your Arduino setup.
Yep - check for any "Updatable" libraries in the Arduino Library Manager.
May also help to make sure all Board Support Packages are up to date.
AndrewElectronics
Thank you for the help! I installed a more recent version of Arduino IDE, updated all the libraries, and it works perfectly now. Thank you again for your help.
Return to “CLUE Board”
