I recently ordered\received a picamera v2, not 2.1 that i'm trying to get to work on a clean install of bullseye. I have tried a p3b, a zero2 and a zero (both zeros use the correct csi cable). I'm fairly certain i have the cable seated correctly but am not getting the camera to work.
Any ideas? I can try buster, i had thought the v2 would have worked fine or i would have ordered the v3.
picamera v2
- kpnobvious
Re: picamera v2
this is from buster on a pizero w v 1.1
[ 15.282115] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 15.289771] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 15.291021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 15.319819] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 16.137677] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 16.139274] bcm2835-v4l2-0: scene mode selected 0, was 0
[ 16.141761] bcm2835-v4l2-0: V4L2 device registered as video0 - stills mode > 1280x720
[ 16.157090] bcm2835-v4l2-0: Broadcom 2835 MMAL video capture ver 0.0.2 loaded.
picamera is enabled in raspi-config
vcgencmd get_camera reports
supported=1 detected=1
libcamera-still isn't installed
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
- kpnobvious
Re: picamera v2
i did try the information posted in these threads
viewtopic.php?p=882952
viewtopic.php?p=804896
viewtopic.php?t=136864
viewtopic.php?p=771669
"raspistill" Camera App (commit bab9bf8790cd Tainted)
Camera Name imx219
Using camera 0, sensor mode 0
GPS output Disabled
Quality 85, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Time delay 5000, Timelapse 0
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Flicker Avoid Mode 'off'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Camera Name imx219
GPS output Disabled
Quality 85, Raw no
Opacity 255
Re: picamera v2
Have you reseated all the connections, including the Kapton tab that connects the CCD module to the PCB?
Re: picamera v2
Thanks.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement.
