negative altitude out of the bme280
mromero
Post by mromero »
i am running a BME280 on a datalogger shield and Metro 328 all from adafruit. Using I2C connection
for some reason the output using the example bme280 test is negative? I attched the code used in case i have a typo y missed.
  This is a library for the BME280 humidity, temperature & pressure sensor
  Designed specifically to work with the Adafruit BME280 Breakout
  ----> http://www.adafruit.com/products/2650
  These sensors use I2C or SPI to communicate, 2 or 4 pins are required
  to interface. The device's I2C address is either 0x76 or 0x77.
  please support Adafruit andopen-source hardware by purchasing products
  from Adafruit!
  Written by Limor Fried & Kevin Townsend for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
  See the LICENSE file for details.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 10
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme; // I2C
//Adafruit_BME280 bme(BME_CS); // hardware SPI
//Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
unsigned long delayTime;
    Serial.begin(9600);
    while(!Serial);    // time to get serial running
    Serial.println(F("BME280 test"));
    unsigned status;
    // default settings
    status = bme.begin();
    // You can also pass in a Wire library object like &Wire2
    // status = bme.begin(0x76, &Wire2)
    if (!status) {
        Serial.println("Could not find a valid BME280 sensor, check wiring, address, sensor ID!");
        Serial.print("SensorID was: 0x"); Serial.println(bme.sensorID(),16);
        Serial.print("        ID of 0xFF probably means a bad address, a BMP 180 or BMP 085\n");
        Serial.print("   ID of 0x56-0x58 represents a BMP 280,\n");
        Serial.print("        ID of 0x60 represents a BME 280.\n");
        Serial.print("        ID of 0x61 represents a BME 680.\n");
        while (1) delay(10);
    Serial.println("-- Default Test --");
    delayTime = 1000;
    Serial.println();
    printValues();
    delay(delayTime);
void printValues() {
    Serial.print("Temperature = ");
    Serial.print(bme.readTemperature());
    Serial.println(" °C");
    Serial.print("Pressure = ");
    Serial.print(bme.readPressure() / 100.0F);
    Serial.println(" hPa");
    Serial.print("Approx. Altitude = ");
    Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
    Serial.println(" m");
    Serial.print("Humidity = ");
    Serial.print(bme.readHumidity());
    Serial.println(" %");
    Serial.println();
output bme280.png (20.13 KiB) Viewed 510 times
Re: negative altitude out of the bme280
Have you set the current sea-level pressure as reported by your local weather station?
sj_remington
Post by sj_remington »
Change this line to the current sea level pressure in your area.
mromero
Post by mromero »
No i did not realize i had to change that i will find it and try that thanks
Note that this will change with the weather. Pilots need to calibrate their altimeters to the ground-based sensors at the airport prior to takeoffs and landings.
sj_remington
If you know the current altitude, it is very simple to calibrate the altimeter by calculating the equivalent sea level pressure, and then back-substitute. Subsequently the measured altitude will agree with the actual altitude, until the local air pressure changes significantly (can happen in minutes, or remain stable for days).
See this overview: https://en.wikipedia.org/wiki/Barometric_formula
Return to “Other Arduino products from Adafruit”
