hello, thanks, first time posting.
Model: NeoPixel Trinkey M0 Board-ID: SAMD21E18A-NeoTrinkey-v0
in TRINKEYBOOT, there is a file named 'INFO_UF2.TXT'
when is normal mode, by that i mean, non-firmware mode.
i need my python script to
copy TRINKEYBOOT/INFO_UF2.TXT to CIRCUITPY/INFO_UF2.TXT
thanks, david
how to copy a file from firmware storage to CIRCUITPY
- asdffdsa6132
- dastels
Re: how to copy a file from firmware storage to CIRCUITPY
You have no access to TRINKEYBOOT in non-bootloader mode.
Why do you need to do this? There might be a better/possible way.
- asdffdsa6132
i am sure there is ;wink
basically, TRINKEYBOOT has over 7.0MiB free.
so i thought that i could store files there,
then from code.py, save to CIRCUITPY or push that file over usb keyboard.
or can we reserve a chunk of TRINKEYBOOT so that it is accessible to code.py
- neradoc
Hi, the BOOT drive does not exist, it's simulated for the single purpose of flashing the firmware with a UF2 file.
It presents a large size so that host operating systems don't reject UF2 files because of their size, regardless of the actual available flash.
As the product page mentions, the Trinkey has a SAMD21 chip with 256kB of flash, and no external flash. Most of it is occupied by Circuitpython itself, leaving 48kB for the user's files as CIRCUITPY.
- asdffdsa6132
thanks,
my goal is that when i plugged in the key into a computer,
that CIRCUITPY is empty, no files at all.
then via code.py, copy a file from firmware to CIRCUITPY.
for example,
.bek, used to unlock bitlocker on boot.
.key used to unlock keepass.
and about `microcontroller.nvm`, seems there is 256Bytes.
is that something boot.py and code.py can use? or is it reserved for the firmware?
for example,
- dastels
First, as neradoc said, TRINKEYBOOT (or any of the BOOT "drives") aren't flash drives. They are the bootloader exposed as a fake flash drive so you can copy a UF2 firmware file to the board rather than have to use a special programmer (e.g. J-LINK). IT ISN'T A DRIVE, it just looks like one to trick your OS.
Second, as I said, you can't access one from the other. If you have a BOOT "drive" the bootloader is running. If you have the CIRCUITPY drive CircuitPython is running.
End of discussion.
End of discussion.
- neradoc
You want the files to be hidden when the board mounts ?
Like some sneaky protection feature by pretending it's an empty USB key ?
And make them appear, how would you want to trigger that ?
That's not something that you could do without making a custom build of Circuitpython, code.py at least would have to be there, and then there are other problems with writing files and having them seen by the PC. You can hide the drive altogether from boot.py, and only mount it in some circumstances, although the board doesn't have a lot of inputs to trigger something like that. If you want a sneaky drive it might possible to write that in Arduino with tinyusb, by swapping between two partitions.
- asdffdsa6132
good idea, mounting on the fly could work, but i think would be difficult to debug.
true, basically two buttons.
with code.py, if i press the correct morse code sequnce, then the triggers some action.
i think for now, store the files in CIRCUITPY in crypted format.
then use code.py to decrypt them.
thanks much,
david
thanks much,
david
- asdffdsa6132
tried to delete this post, but was not allowed
- dastels
- asdffdsa6132
thanks,
when i reset the device by pressing the reset button. i get the expected behavior.
--- boot.py creates a text file named 'boot.ext', that works fine.
--- code.py creates a text file, named 'code.ext' that works fine.
but after that,
if i delete 'code.ext' and re-run code.py, code.py does NOT recreate the text file.
only after hard reset, will code.py create the text file
boot.py
code.py
but after that,
boot.py
supervisor.runtime.rgb_status_brightness = 5
storage.remount("/", readonly=False, disable_concurrent_write_protection=True)
with open('/boot.ext', 'w') as f:
f.write('boot')
with open('/code.ext', 'w') as f:
f.write('code')
- dastels
I believe you risk corrupting the filesystem if both CircuitPython and your computer have write access at the same time, I.e. if boot.py mounts it as writable, you shouldn't write to it from your computer.
This is noted explicitly in a bright red warning block on that page I inked to:
The typical usecase is for boot.py to make it writable when it's running without USB connected: to be able to log readings and such. That's why it's usually done conditionally on some input. I.e. you boot it in "running mode" or "programming mode".
Ignore that at your own risk.You can only have either your computer edit the CIRCUITPY drive files, or CircuitPython. You cannot have both write to the drive at the same time. (Bad Things Will Happen so we do not allow you to do it!)
- asdffdsa6132
ok, first of all, the trinkkey is fantastic and so is the tech support here.
so i figured out what is going on,
when using this command
`storage.remount("/", readonly=False, disable_concurrent_write_protection=True)`
if {boot|code}.py creates a file, the file is created, but not visible to the host.
and that is ok, i can work around that.
- neradoc
USB drives are not supposed to change on their own, so operating systems and drivers on the host side can cache the content, and not show changes that you made until the board is unmounted (by "ejecting" it in the OS for safety) and remounted (with a reset).asdffdsa6132 wrote: ↑Sun Feb 19, 2023 7:04 pm if i delete 'code.ext' and re-run code.py, code.py does NOT recreate the text file.
Even worse, it could overwrite the changes if you put it in a non safe mode, by writing the cache back if, say, it saves some metadata like the access time of the file when it reads it. That's one of that way that the unsafe mode can corrupt the drive, which can also happen if both side write at the same time, overwriting each other.
boot.py runs before the USB drive is mounted, so the changes would be visible to the PC, but code.py runs after that, so if the PC accessed the drive and cached it, there is a possibility that the changes are not seen.
- dastels
That warning wasn't just for fun, you know.
