Picade video is poor - hard to see
- ntheath
So I got my Picade bulit up with RP3+. Initially had the issue where the video wouldn't show up and had to change the config.txt file. That got me past the "no signal found" error, which was really hard to read. I thought it was just a default mode that was hard to read. After I fixed that, I can see retropie load and emulation station start, but the video quality is poor and hard to see. I don't think this is normal - but i'm not sure what the issue is. I tried supplying 5V from a separate wall transformer to the display board to rule out power droop from the RPI's USB port but that doesn't change anything. I have the official RPI USB C power supply I got with the Picade kit. Is this a defective LCD? This is a kit I just ordered from Adafruit.
- IMG_2701.jpg (786.78 KiB) Viewed 74 times
- mikeysklar
Re: Picade video is poor - hard to see
Congrats on getting the Picade built and running.
The Pimoroni products are supported through their forums.
There is a post about the HDMI driver board having brightness settings you can adjust.
The new Picade (2018) does have a hdmi display driver board with it. You can adjust brightness and contrast etc although the problem I’m having is that it never remembers the previous setting after turning it on and off so you have to adjust everytime.
- ntheath
Thanks. I'll post over there.
The issue I'm having is I can't even read the menu when I do enter those settings via the keypad. The photo I took there with my phone actually looks readable, but IRL its not. The camera does a lot to enhance the view. Kinda hard to adjust settings when I can't read them :).
- ntheath
So I checked out the Pimoroni forums and I found that a lot Picade related questions have gone unanswered and are old. So that's not encouraging.
Can someone at Adafruit please assist? My order number is #3015089-3918814631.
I can upload some more pics of the screen, I checked the brightness level and its already maxed out. The whole LCD is just washed out. Its unplayable in this state.
- IMG_2704.jpg (120.45 KiB) Viewed 58 times
- mikeysklar
