The bme280 sensor keeps displaying 182 degrees.
MakerScientist
Post by MakerScientist »
The bme280 sensor keeps displaying 182 degrees. Why? I am using it by connecting it to the Arduino nano, and one oled display is also connected.
#include "settings.h"
#define limitT 33
float temperature;
float maxT, minT;
void setup()   {
Serial.begin(9600);
delay(250);
display.begin(i2c_Address, true);
Serial.println("3D 프린팅 챔버 항온유지장치");
pinMode(12, OUTPUT);
unsigned status;
status = bme.begin();
Serial.println(status);
if (!status) {Serial.println("온도센서 오류!");}
Serial.println("온도센서 정상");
temperature=bme.readTemperature();
maxT=temperature;
minT=temperature;
Serial.println("루프돌입!");
if (temperature>maxT) {maxT=temperature;}
if (temperature<minT) {minT=temperature;}
if (temperature>limitT) {digitalWrite(12, 1);}
else {digitalWrite(12, 0);}
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(SH110X_WHITE);
display.setCursor(0, 0);
display.println("OPERATING!");
display.print("T: "); display.println(temperature);
display.print("MAX: "); display.println(maxT);
display.print("MIN: "); display.println(minT);
display.print("LIMIT: "); display.println(limitT);
display.print("TIME: "); display.println("inf");
display.display();
Serial.println(temperature);
delay(1000);
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme;
unsigned long delayTime;
#define i2c_Address 0x3c
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1   //   QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT,
&Wire, OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
Last edited by adafruit_support_carter on Wed Feb 22, 2023 1:02 pm, edited 1 time in total.
Reason: added [code] tags
Re: The bme280 sensor keeps displaying 182 degrees.
Try running just the BME280 example sketch shown in the guide:
https://learn.adafruit.com/adafruit-bme ... duino-test
What values does that sketch report from the BME280?
MakerScientist
It show 23 degree but I did not check after one day. I will try and reply. Thank you
MakerScientist
I checked and it works fine after 24h.
Than, it looks like the sensor is not the problem.
Could you please suggest what can cause such error according to my code?
In your sketch, you are displaying the temperature on both the OLED and the Arduino Serial Monitor. Does the 128 value show up in both places?
MakerScientist
yes both monitor shows 182 degree.
I found that nano keeps resetting.
so I think it is maybe memory issue.
I deleted OLED code, and it works fine.
I want to hear your opinion too.
Memory or some other code issue. The BME280 stand alone example works as expected. So it's not a hardware issue.
Return to “Arduino”
