Hi - I'm using the Adafruit IO Arduino library with ESP32, MQTT and the Adafruit IO dashboard data display system.
I'm trying to obtain some retained values from my feeds. The Adafruit method for this is described in the Adafruit IO HTTP API in the section "Using the */get topic":
https://io.adafruit.com/api/docs/mqtt.h ... -get-topic
However, that document is missing a key piece of information.
In the documentation (linked above) it says the following:
"If you’re using the Adafruit IO Arduino library, you can add /get support to your project in one line of code:"
....but where that line of code should be displayed, it's blank.
After the blank space, it goes on to correctly describe how to do this with the Adafruit IO CircuitPython library in one line of code, but I need the one line of code that lets me do it with the Adafruit IO Arduino library.
Can anyone tell me what the missing line is? Thanks....
Adafruit IO Arduino Library HTTP API "/get" documentation error
- chicoDaMan
Re: Adafruit IO Arduino Library HTTP API "/get" documentation error
Hmm.. I'll pass that along to the documentation team.
- brubell
- Learn User Page
Hi, we've added this code snippet to the page:
Thank you for bringing this to our attention!
// ... from the adafruitio_01_subscribe example sketch
AdafruitIO_Feed *counter = io.feed("counter");
// 1. start IO connection
io.connect();
// 2. prepare MQTT subscription with handler function
counter->onMessage(handleMessage);
// 3. wait for successful connection
while(io.mqttStatus() < AIO_CONNECTED) {
delay(500);
// 4. send /get message, requesting last value, triggering
// the handleMessage handler function
counter->get(); // ask Adafruit IO to resend the last value
