SdFat Adafruit Fork library V1.5.1 vs. V2.2.1
stratosfear
Post by stratosfear »
The code below is an abbreviated version of VolumeFreeSpace.ino modified for flash memory on an ItsyBitsy M0. It compiles and runs with the SdFat Adafruit Fork library V1.5.1. If the library is updated to V2.2.1, Arduino reports compile errors related to cout and vol(). Any suggestions other than staying with V1.5.1?
#include "Adafruit_SPIFlash.h"
Adafruit_FlashTransport_SPI flashTransport(EXTERNAL_FLASH_USE_CS, EXTERNAL_FLASH_USE_SPI);
Adafruit_SPIFlash flash(&flashTransport);
// file system object
FatFileSystem fatfs;
static ArduinoOutStream cout(Serial);
  Serial.begin(115200);
  delay(5000);  //cheapshot delay
  printFreeSpace();
  // infinite loop!!!
void printFreeSpace() {
  File flashFile;   //file on flash
  flash.begin();
  fatfs.begin(&flash);
  cout << F("freeClusterCount() call time: ");
  uint32_t m = micros();
  uint32_t volFree = fatfs.vol()->freeClusterCount();
  cout << micros() - m << F(" micros\n");
  cout << F("freeClusters: ") <<  volFree << setprecision(3) << endl;
  float fs = 0.000512*volFree*fatfs.vol()->blocksPerCluster();
  cout << F("freeSpace: ") << fs << F(" MB (MB = 1,000,000 bytes)\n\n");
Return to “Itsy Bitsy Boards”
