My class has been working with CPG and MakeCode the last few weeks. We noticed some programs start and then the CPG goes to a mix of blue and red LEDs and stops operating. What does this mean? It is usually the same pattern and I have tried multiple CPG devices....... I can attach a picture if helpful showing the blue red pattern..... D13 small red LED is flashing also...
What does it mean when CPG shows Red and Blue?
- dastels
Re: What does it mean when CPG shows Red and Blue?
What are you calling a CPG? Sounds like a CircuitPlayground Express if you're using MakeCode.
- TechEd
Yes - circuit playground express.
- TechEd
- dastels
What code are you running? A screenshot of the block code is probably good as long as it's readable.
- TechEd
A screenshot will have to wait a few days until I have the students back in class. I will add that this has happened with several different groups using different programs. Does the red/blue combo denote a programming/code error?
- dastels
I'm looking into it.
- adafruit2
thats an internal error code - something 'crashed' inside of makecode. best bet is to post the code. sometimes this happens when people do wierd things with servos or detaching/attaching pins
- TechEd
Many thanks. One additional bit, maybe helpful, maybe not, the students have been using the temperature sensor and corresponding MakeCode blocks …… if temperature in F is greater than loops…
I don’t know if that’s pertinent.
- adafruit2
we'd really need to see a screenshot of the code to be able to know whats happening
- petespaco
Just out of curiosity, could you load (or have you loaded) any programs that don't do that?
Maybe some Ardino IDE sample.
