How do I use multiple file tabs for simple rx code and tx code for Radio?
animefruit
Post by animefruit »
Hello.
This is Neal.
I am person that does Arduino Projects.
I am trying to transform the simple "RadioHead69_RawDemo_RX" example code and the "RadioHead69_RawDemoTX" example code to have multiple file tabs.
I already did it succesfully with the TX code but now I need to do it with the RX code.
The problem is that in the RX code gives me an error that says:
"error: 'radio_setuprx' was not declared in this scope"
I don't know how to fix this.
Can you help?
Here is my code:
the first tab is called "Radio RX" and the code is this:
 #include "radio_setuprx.h"
  // put your setup code here, to run once:
radio_setuprx();
  // put your main code here, to run repeatedly:
The other tab is "radio_setuprx" which has this code from the "RadioHead69_RawDemo_RX" example code like this:
#include <SPI.h>
#include <RH_RF69.h>
/************ Radio Setup ***************/
// Change to 434.0 or other frequency, must match RX's freq!
#define RF69_FREQ 915.0
#if defined (__AVR_ATmega32U4__) // Feather 32u4 w/Radio
  #define RFM69_CS      8
  #define RFM69_INT     7
  #define RFM69_RST     4
  #define LED           13
#endif
#if defined(ADAFRUIT_FEATHER_M0) || defined(ADAFRUIT_FEATHER_M0_EXPRESS) || defined(ARDUINO_SAMD_FEATHER_M0)
  // Feather M0 w/Radio
  #define RFM69_CS      8
  #define RFM69_INT     3
  #define RFM69_RST     4
  #define LED           13
#endif
#if defined (__AVR_ATmega328P__)  // Feather 328P w/wing
  #define RFM69_INT     3  //
  #define RFM69_CS      4  //
  #define RFM69_RST     2  // "A"
  #define LED           13
#endif
#if defined(ESP8266)    // ESP8266 feather w/wing
  #define RFM69_CS      2    // "E"
  #define RFM69_IRQ     15   // "B"
  #define RFM69_RST     16   // "D"
  #define LED           0
#endif
#if defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2) || defined(ARDUINO_NRF52840_FEATHER) || defined(ARDUINO_NRF52840_FEATHER_SENSE)
  #define RFM69_INT     9  // "A"
  #define RFM69_CS      10  // "B"
  #define RFM69_RST     11  // "C"
  #define LED           13
#elif defined(ESP32)    // ESP32 feather w/wing
  #define RFM69_RST     13   // same as LED
  #define RFM69_CS      33   // "B"
  #define RFM69_INT     27   // "A"
  #define LED           13
#endif
#if defined(ARDUINO_NRF52832_FEATHER)
  /* nRF52832 feather w/wing */
  #define RFM69_RST     7   // "A"
  #define RFM69_CS      11   // "B"
  #define RFM69_INT     31   // "C"
  #define LED           17
#endif
/* Teensy 3.x w/wing
#define RFM69_RST     9   // "A"
#define RFM69_IRQ     4    // "C"
#define RFM69_IRQN    digitalPinToInterrupt(RFM69_IRQ )
/* WICED Feather w/wing
#define RFM69_RST     PA4     // "A"
#define RFM69_CS      PB4     // "B"
#define RFM69_IRQ     PA15    // "C"
#define RFM69_IRQN    RFM69_IRQ
// Singleton instance of the radio driver
RH_RF69 rf69(RFM69_CS, RFM69_INT);
int16_t packetnum = 0;  // packet counter, we increment per xmission
void setup()
  Serial.begin(115200);
  //while (!Serial) { delay(1); } // wait until serial console is open, remove if not tethered to computer
  pinMode(LED, OUTPUT);
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, LOW);
  Serial.println("Feather RFM69 RX Test!");
  Serial.println();
  // manual reset
  digitalWrite(RFM69_RST, HIGH);
  delay(10);
  delay(10);
  if (!rf69.init()) {
    Serial.println("RFM69 radio init failed");
    while (1);
  Serial.println("RFM69 radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
  // No encryption
  if (!rf69.setFrequency(RF69_FREQ)) {
    Serial.println("setFrequency failed");
  // If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
  // ishighpowermodule flag set like this:
  rf69.setTxPower(20, true);  // range from 14-20 for power, 2nd arg must be true for 69HCW
  // The encryption key has to be the same as the one in the server
  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
  rf69.setEncryptionKey(key);
  Serial.print("RFM69 radio @");  Serial.print((int)RF69_FREQ);  Serial.println(" MHz");
 if (rf69.available()) {
    // Should be a message for us now
    uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
    uint8_t len = sizeof(buf);
    if (rf69.recv(buf, &len)) {
      if (!len) return;
      buf[len] = 0;
      Serial.print("Received [");
      Serial.print(len);
      Serial.print("]: ");
      Serial.println((char*)buf);
      //Serial.print("RSSI: ");
      //Serial.println(rf69.lastRssi(), DEC);
//      if (strstr((char *)buf, "Hello World")) {
//        // Send a reply!
//        uint8_t data[] = "And hello back to you";
//        rf69.send(data, sizeof(data));
//        rf69.waitPacketSent();
//        Serial.println("Sent a reply");
//        Blink(LED, 40, 3); //blink LED 3 times, 40ms between blinks
//    } else {
//      Serial.println("Receive failed");
//void Blink(byte PIN, byte DELAY_MS, byte loops) {
//  for (byte i=0; i<loops; i++)  {
//    digitalWrite(PIN,HIGH);
//    delay(DELAY_MS);
//    digitalWrite(PIN,LOW);
//    delay(DELAY_MS);
And the last tab is called "radio_setuprx.h which just has the top part of the "RadioHead69_RawDemo_RX" example code like this:
 #include <SPI.h>
  #define RFM69_CS      8
  #define RFM69_INT     7
  #define RFM69_RST     4
  #define LED           13
#endif
  #define RFM69_CS      8
  #define RFM69_INT     3
  #define RFM69_RST     4
  #define LED           13
#endif
  #define LED           13
#endif
  #define LED           0
#endif
  #define LED           13
  #define LED           13
#endif
  #define LED           17
#endif
Can you tell me how to fix the error?
Here is a picture so you know what I mean by tab files in the code.
The tab files are right above the code.
Code for RX.png (38.87 KiB) Viewed 90 times
mikeysklar
Re: How do I use multiple file tabs for simple rx code and tx code for Radio?
Post by mikeysklar »
Your header file radio_setuprx.h does not contain a function called radio_setuprx()
animefruit
Ok. I fixed that. It works great now for that.
Return to “Arduino”
