I’m trying to make a wearable sensor that gives a result about force being applied on someone’s foot.
Which sensor should I use? I’m thinking about using a force sensitive resistor but I don’t know how to connect more than one on a single arduino and get an overall result. Also, a load cell wouldn’t help because I need it to be a wearable.
Any advice would be helpful.
Thank you,
Daphne
Wearable force / pressure sensor
Re: Wearable force / pressure sensor
This guide shows how to connect and read values from an FSR: https://learn.adafruit.com/force-sensit ... r/overview
To connect more than one FSR, you would connect each one to a different analog pin and combine the readings as needed in your code.
