Voice bonnet push button not working
ps_nithin
Post by ps_nithin »
I am not able to get the push button on my voice bonnet connected to pi zero w working. I have connected another push button on another GPIO and with the same code it is working as expected. Any ideas about the possible issue with the push button on the bonnet.
This is my code which I copied from adafruit guide.
import time
import board
from digitalio import DigitalInOut, Direction, Pull
button = DigitalInOut(board.D17)
button.direction = Direction.INPUT
button.pull = Pull.UP
while True:
  if not button.value:
    print("Button pressed")
  time.sleep(0.01)
dastels
Re: Voice bonnet push button not working
Post by dastels »
If you have a meter you can test the button directly (without the Pi powered off or disconnected). Opposite corners should be connected when it is pressed.
ps_nithin
Post by ps_nithin »
I checked with a multimeter continuity test and the switch is not faulty.
dastels
Post by dastels »
It's sounding like a problem between the button and the GPIO header.
Please email [email protected] with a link to this thread, your order number, and request the replacement of one Voice Bonnet.
