Talking from one pico to 4 others
- knox1138
Is it possible for one pico to talk to 4 others? Like daisy chaining uart? I have a robotic arm project idea and in my head that would have 4 encoded motors and what made sense to me was to use a pico to for each motor to handle position and speed and then use one pico to tell those four what they need to do, but I don't see an obvious solution for one controller to talk to 4 others with circuitpython.
- mikeysklar
Re: Talking from one pico to 4 others
The Pico W has WiFi so problem solved right? You can run a webserver one one and pull data from it with the other 4.
https://learn.adafruit.com/pico-w-http- ... cuitpython
If it is possible to do a task with one controller that would probably be better than using 5. It is not clear to me why adding 4 boards would be necessary. Would the Maker Pi help remove the additional controllers?
https://www.adafruit.com/product/5129
If you really do need a bunch of boards and do not want to use WiFi consider a single Raspberry Pi 4 with 4x Picos plugged in via USB. The Pi can have a collection Python script running to send and receive data to the slave Picos
