IO / Wippersnapper does not detect Adafruit Huzzah32
adafruit.io wippersnapper BETA support, discussions, and more!
TimJan
Post by TimJan »
I have now tried the entire evening to detect a Adafruit Huzzah using Adafruit IO, but I only get to the "Download firmware" stage every time.
The firmware seems to go through.
I have created a guest network with only 2.4ghz.
But it does not detect it.
The yellow blink is flashing rapidly, nothing else.
brubell
Learn User Page
Re: IO / Wippersnapper does not detect Adafruit Huzzah32
Post by brubell »
Hi TimJan,
Do you see the WIPPER drive on your computer? Within the secrets.json file - are all the credentials correct (please check for case sensitivity and verify that your IO key is correct too)
Shoggoth
Post by Shoggoth »
I have a similar problem with an Adafruit Huzzah32 V2. The board with ESP32 chip, 8MB Flash, 2MB PSRAM, and connector for external antenna.
I have two of these boards and neither will connect to Adafruit IO. When I flash them with CircuitPython, both of them connect to my wireless network and receive an IP address. When I flash them with Wippersnapper, neither will connect to wireless and the status light goes into a very slow (several seconds) blink. I assume it is a boot loop. I do not see the WIPPER drive on my computer. Any thoughts would be greatly appreciated.
brubell
Learn User Page
Post by brubell »
Shoggoth wrote: Thu Apr 06, 2023 12:33 pm Hello,
Could you open a bug report on the WipperSnapper repository: https://github.com/adafruit/Adafruit_Wi ... .md&title=
Shoggoth
Post by Shoggoth »
Done.
github.com/adafruit/Adafruit_Wippersnapper_Arduino/issues/424
brubell
Learn User Page
Post by brubell »
Thanks, I'll take it from there!
dobbsjs
Post by dobbsjs »
Hello,I just wanted to mention that I have the same issue. Thank you for taking up this issue, I will wait for any updates on this.
brubell
Learn User Page
Post by brubell »
dobbsjs wrote: Sat Apr 08, 2023 12:18 am Hello,I just wanted to mention that I have the same issue. Thank you for taking up this issue, I will wait for any updates on this.
Tracking via this issue: https://github.com/adafruit/Adafruit_Wi ... issues/424. Please add any relevant info you have there.
Return to “Adafruit IO Wippersnapper Beta”
