I'm working on a project with a Feather rp2040, Music Maker Featherwing and an I2S MEMS mic (SPH0645LM4H). More details here:viewtopic.php?t=199360
My problem is that I am only getting -1 or 0 from the mic. I have the mic connected through the STEMMA connector, thinking that that would be convenient: 3v, gnd, BCLK and LRCLK. Data is on GPIO7. I eventually figured out that BCLK and LRCLK have to be consecutive pins, something that was not obvious to me, and with that change I was able to i2s.begin() and start reading data. For testing I'm using the I2SInput example from the Philhower lib, which is about as minimal as a test case could be. BCLK=PIN_WIRE_SDA, LRCLK=BCLK+1, DATA=7.
The problem is, all I get are -1, -1 from the left and right channel. Weirdly, if I try to shut the rp2040 down via the EN pin, I start getting 0, 0 and the sketch just keeps going (see my other post for details). I'm not sure if that is significant or not. No amount of noise in the vicinity of the mic produces any other result in either mode of operation.
I've purchased another mic, thinking that I might have accidentally killed the first one while cleaning up my solder joints, but I'm getting the same results. Any suggestions?
I2S not working on a Feather rp2040
- Stain
Re: I2S not working on a Feather rp2040
I would like to resurrect this topic. I have acquired a new Feather RP2040, which has a working EN pin. Hooking up the I2S MEMS mic on this feather, exactly as described above, I get nothing but 0s. There's nothing else attached to this feather ATM. Still running the I2SInput example code, the only change being to set the DATA pin to 7 and BCLK to 2.
Any thoughts?
Any thoughts?
- MEMS mic only.jpg (987.71 KiB) Viewed 38 times
- Stain
Oh, and the soldering from the other side
- MEMS mic only bottom.jpg (325.42 KiB) Viewed 38 times
