Hello, I am using an Adafruit 12v DC stepper motor hat (part# 2348) to drive a 5v-12v 3-wire stepper motor (DIY DM996). Adafruit displays them in various tutorials, however the connections are always obscured. And that's precisely the problem I'm having.
With a three-wire stepper, I need to know exactly where the red, yellow/orange and brown wires go. I've tried M1, then M2, M3 and M4. Then I tried straddling M3 and M4, which actually made the motor move. This latter configuration was utterly uncontrollable, but illustrated that something might work. Has anyone made the 3-wire stepper work using the small Adafruit 2348, 5v/12v stepper motor hat work? BTW, the stepper motor works using native raspi PWM.
Adafruit stepper motor driver hat (part 2348)
- rlbaldwin
Re: Adafruit stepper motor driver hat (part 2348)
Please post a link to the motor you are using. What you describe sounds more like an RC servo motor.
- rlbaldwin
Yes, it is commonly used to power RC devices like steering control, etc. The 996 is much like the SG90, but stronger.
Here is the datasheet: https://components101.com/motors/mg996r ... -datasheet
I've used the source code on Adafruit to run the motor, but the code doesn't have limits to specifically control movement through 0-180 degrees of rotation. I'll hunt for an alternate bit of source code for a better test.
What you have there is an RC servo motor. It is not a stepper motor and cannot be controlled by the DC & Stepper Motor HAT.
RC servos are controlled via PWM pulses. What you need for that motor is the PWM/Servo HAT: https://www.adafruit.com/product/2327
- rlbaldwin
Thank you. Clearly did not understand the difference between "stepper" and "servo" motors.
