When I first purchased two SCD 41 from Adafruit I was able to get it up and running using the ExampleUsage on the Feather ESP32V2 with no problem. Now however when I try to upload the code to the other SCD41 w. ESP32V2 I get a compilation error:
exec: "/esptool.exe": file does not exist
Compilation error: exec: "/esptool.exe": file does not exist
This occurs even though I installed the SCD4x Adafruit library. Any help is appreciated as always!
thanks,
Andrew
p.s. I have the other ESP32v2 with the second SCD41 successfully connected via wippersnapper to the Adafruit IO
SCD 41 CO2 sensor
- siquepuede
Re: SCD 41 CO2 sensor
Additional note: I just tried using the SCD41 with a 8266 NodeMCU and the code uploaded and worked fine.
Also can connect two of the same boards on wippersnapper using the adafruit IO? Is there a way to change the name so that they are distinguishable? sorry for the basic question - I am somewhat new to the IO world!
Andrew
Andrew
Check to make sure you have the latest version of the ESP32 Board Support Package. The toolset evolves over time, and it sounds like you may have code that's calling a piece that's no longer current.
- brubell
- Learn User Page
You can change the device's name. Go to the Device's page and click "Device Settings". From there, there is a form that allows you to change the device name.Also can connect two of the same boards on wippersnapper using the adafruit IO? Is there a way to change the name so that they are distinguishable? sorry for the basic question - I am somewhat new to the IO world!
Andrew
- siquepuede
Thank you for your helpful response. I'll try your recommendation. And thanks for the answer to my other question about renaming board.
Just wanted to add that I used the CO2 sensor with my 8th grade science class today and they were able to see first hand the rapid rise of CO2 levels with candle burning under a jar (with SCD41 next to it) as well as evidence of their own CO2 exhaled. It is a nifty package and works very well with the ESP32 on WipperSnapper!
thanks for the helpful support!
Andrew
Andrew
- brubell
- Learn User Page
Yay - excellent!Just wanted to add that I used the CO2 sensor with my 8th grade science class today and they were able to see first hand the rapid rise of CO2 levels with candle burning under a jar (with SCD41 next to it) as well as evidence of their own CO2 exhaled. It is a nifty package and works very well with the ESP32 on WipperSnapper!
