Neopixel on Scorpio- is a resistor needed on data line?
- Mikey75075
I am putting together my first project on Scorpio for a number of Neopixel strands. Is the 330ohm resistor on the data line still recommended with Scorpio?
- mikeysklar
Re: Neopixel on Scorpio- is a resistor needed on data line?
The 300 ohm resistor was for the earlier WS2812 versions. The resistor is no longer necessary with modern NeoPixels.
https://learn.adafruit.com/adafruit-neo ... ic-2894462Today’s NeoPixels are fairly robust, but if you have early ones or some “WS2812-compatible” parts, it’s advisable to add a 300–500 Ohm resistor between the microcontroller’s output pin and the NeoPixel input.
- Mikey75075
- adafruit2
FYI there's an inline resistor (100 ohms) on each SCORPIO output!
