Hi all,
Quick question on the wave shield voice changer project that can be found in the Adafruit
https://learn.adafruit.com/wave-shield-voice-changer
It says to use an a Metro 328 but then I would have to learn that language.
Can I use a Metro M0 Express or M4 so I can standardise on Circuit Python?
Will either of these give me the same possibilities as the 328 or even more?
Thanks in advance for your help
Voice changer options
- mikeysklar
Re: Voice changer options
This shield really needs to be used with older models of Arduino boards. It will not work with M0/M4 based boards in Arduino due to the use of registers in the driver code. It also does not have a library for CircuitPython.
The Monster M4SK mask has a voice changer mode (still Arduino based):
https://learn.adafruit.com/adafruit-mon ... -changer-2
You can also use a Raspberry Pi for real time voice changing.
https://planet-geek.com/2015/10/29/hack ... halloween/
