Do the "neon" LED strips such as the 3860 need to have the current limited?
https://www.adafruit.com/product/3860
Regulating power to 3860 LED strips
- mikeysklar
Re: Regulating power to 3860 LED strips
You do not need to limit the current. Just meet the power specs and it is ideal to have a power supply with higher current rating than requried.
What were you using for the power supply with your setup?
Technical Details
Operating Voltage: DC 12V
Current draw: 0.8A per meter at 12V
LED: SMD2835
LED Quantity per Meter: 120 pcs
Waterproof Rating: IP65
Weight: 71g (+/-5)
Product Dimensions: 1,000.0mm x 12.2mm x 5.0mm / 39.4" x 0.5" x 0.2"
Product Weight: 70.0g / 2.5oz
- MV10
A Jeep :)What were you using for the power supply with your setup?
(and... thanks!)
- mikeysklar
You are fine for current, but you will need to watch voltage.
These strips are designed for 9v - 12v. Your Jeep is probably going to run well over that. Car automotive batteries can go up to 15v when driving. A 12v regulator would be a good idea to keep the voltage stable.
- MV10
Ah, makes sense, good to know, thank you.
