Seeking help on BigSeg7x4
eaderigt
Post by eaderigt »
Dear all,
I have set my Raspberry PI up with a BigSeg7x4 display. And I use it to show 3 values that switch a) power usage b) temperature c) wind direction.
In order to switch from one value to the other I use display.fill(0) to clean the display before showing the next one.
It runs fine and can run perfectly for days. Though at some point (sometimes after hours - sometimes after days) my code crashes and I get the error message like below.
It seems to crash on the display.fill(0) line.
>>> %Run knmi_power6.py
File "/home/erik/meter/knmi_power6.py", line 88, in <module>
display.fill(0)
File "/home/erik/.local/lib/python3.9/site-packages/adafruit_ht16k33/ht16k33.py", line 141, in fill
self.show()
File "/home/erik/.local/lib/python3.9/site-packages/adafruit_ht16k33/ht16k33.py", line 128, in show
i2c_dev.write(buffer)
File "/usr/local/lib/python3.9/dist-packages/adafruit_bus_device/i2c_device.py", line 101, in write
self.i2c.writeto(self.device_address, buf, start=start, end=end)
File "/usr/local/lib/python3.9/dist-packages/busio.py", line 174, in writeto
return self._i2c.writeto(address, memoryview(buffer)[start:end], stop=stop)
File "/usr/local/lib/python3.9/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 52, in writeto
self._i2c_bus.write_bytes(address, buffer[start:end])
File "/usr/local/lib/python3.9/dist-packages/Adafruit_PureIO/smbus.py", line 314, in write_bytes
self._device.write(buf)
OSError: [Errno 121] Remote I/O error
This is the Code I use:
import requests
import re
import serial
import time
import board
from adafruit_ht16k33 import segments
custom_chars = {}
custom_chars["z"] = 0b01100011 #gradenteken
custom_chars["g"] = 0b00111001
custom_chars["y"] = 0b00001111 #rechtshaak
custom_chars["x"] = 0b00111001 #linkshaak
custom_chars["w"] = 0b00001110 #rechtsonder
custom_chars["v"] = 0b00111000 #linksonder
custom_chars["u"] = 0b00000111 #rechtsboven
custom_chars["m"] = 0b00110001 #linksboven
custom_chars["n"] = 0b00000001 #boven
custom_chars["q"] = 0b00001000 #onder
custom_chars["k"] = 0b00001001 #onder en boven
i2c = board.I2C()
#display = segments.BigSeg7x4(i2c)
display = segments.BigSeg7x4(i2c, char_dict=custom_chars)
display.brightness = 0.1
# Seriele poort confguratie
ser = serial.Serial()
# DSMR 4.0/4.2 > 115200 8N1:
ser.baudrate = 115200
ser.bytesize = serial.EIGHTBITS
ser.parity = serial.PARITY_NONE
ser.stopbits = serial.STOPBITS_ONE
ser.xonxoff = 0
ser.rtscts = 0
ser.timeout = 12
ser.port = "/dev/ttyUSB0"
ser.close()
erik_temp = 99
erik_dir = 99
teller = 199
while True:
    teller = teller + 1
    if teller == 200:
        res2 = requests.get('https://weerlive.nl/api/json-data-10min.php?key=BANNED&locatie=52.34838940753904,4.906978197204979')
        data2 = res2.json()
        erik_temp = data2['liveweer'][0]['temp']
        erik_dir = int(data2['liveweer'][0]['windrgr'])
        teller = 0
    if 23 <= erik_dir < 68: #noordoost
        erik_dir2 = '__nu'
    elif 68 <= erik_dir < 113: #oost
        erik_dir2 = '__ky'
    elif 113 <= erik_dir <= 158: #zuidoost
        erik_dir2 = '__qw'
    elif 158 <= erik_dir < 203: #zuid
        erik_dir2 = 'vqqw'
    elif 203 <= erik_dir < 248: #zuidwest
        erik_dir2 = 'vq__'
    elif 248 <= erik_dir < 293: #west
        erik_dir2 = 'xk__'
    elif 293 <= erik_dir < 338: #noordwest
        erik_dir2 = 'mn__'
    else:
        erik_dir2 = 'mnnu' #noord
    ser.open()
    checksum_found = False
    #start BANNED inlees loop
    while not checksum_found:
        BANNED_line = ser.readline() # Lees een seriele lijn in.
        #print (type(BANNED_line))
    # check of het de elec regel is
        if re.match(b'(?=1-0:1.7.0)', BANNED_line):
            #check of de regel volledig is
            #print (BANNED_line)
            if re.search(b'(?=\(..\....\*kW\))', BANNED_line):
                elec1 = (BANNED_line[10:16]).decode()
                elec2 = int(float(elec1) * 1000)
                display.fill(0)
                time.sleep(0.01)
                display.print (str(elec2))
                time.sleep(1.6)
                display.fill(0)
                time.sleep(0.01)
                display.print (str(int(float(erik_temp))) + "zc")
                time.sleep(1.6)
                display.fill(0)
                time.sleep(0.01)
                display.print (str(erik_dir2))
                time.sleep(1.2)
            else:
                pass
    # Check wanneer het uitroepteken ontvangen wordt (einde BANNED inlees loop)
        if re.match(b'(?=!)', BANNED_line):
            checksum_found = True
    ser.close()
thank you ,
Erik
mikeysklar
Re: Seeking help on BigSeg7x4
Post by mikeysklar »
The only slightly related issue I see looks resolved. display.fill() would fail when display.auto_write was not set to True.
You could try adding some try/except logic to catch the error and continue.
  try:
    display.fill(0)
  except OSError as error:
    print(error)
    print("can't stop me now")
Finally, how is your wiring and soldering? Anything unstable?
eaderigt
Post by eaderigt »
hello mikey,
Thank you. I have the code now running including your suggestion. And will report here if it not crashing on the display.fill(0) lines.
Soldering and wiring has been strong and during the set up I spent time taking away all weak spots in the wiring and soldering.
mikeysklar
Keep a REPL console open if possible. This will print out the errors should they still be occurring.
eaderigt
Post by eaderigt »
I have that.
It is running smoothly. I will report here once it crashes or when it runs for a full week.
mikeysklar
Cool. Still running. Thanks for the update.
eaderigt
Post by eaderigt »
hi mike,
OK. Cool. you did it. It is still running at the moment.
But we did pass the crucial moment without crashing.
Screenshot 2023-03-15 at 08.02.01.png (623.98 KiB) Viewed 214 times
I want to thank you a lot! because this had been bothering me for weeks/months.
mikeysklar
Yes! I love it when these simple work arounds avoid a crash. Thank you for the follow up and the screenshot.
eaderigt
Post by eaderigt »
hi Mike,
Quick update for your information. My code crashed once but unfortunately I did not get the message from the shell.
It is certainly more stable than it used to be.
Example screenshot is from that last 48 hours and we see it hit the crucial point twice.
I am waiting now to see if it crashes again. I am close to 99% certain it crashed on something else than the display fill.
Screenshot 2023-03-21 at 07.13.01.png (200.83 KiB) Viewed 182 times
mikeysklar
I'm glad it is more delayed, but that error message does look the same as the one that was triggered by display.fill(0).
There is something you can try and it is not an elegant solution or even a fix. One thing that can happen on occasion with i2c devices is they fall off the i2c bus. You might be able to scan for them and get them back on the bus.
You could add this bit of scan logic to the error condition and see if the device can recover. Place the imports as the top of the file.
import os
from time import sleep
os.system('i2cdetect -y 1')
sleep(0.1)
eaderigt
Post by eaderigt »
thanks mike,
it has now been running for the past 4/5 days without ny messages in the shell. So that is good.
Still I will work on your suggestion - to see if it helps for more stability.
Will continue to inform here.
mikeysklar
That is good progress @ 5days and running.
Did you add the i2cdetect or is this running without it?
Thank you for the update.
eaderigt
Post by eaderigt »
currently still without it and still running.
Nice empty shell
Screenshot 2023-03-27 at 06.45.04.png (88.93 KiB) Viewed 160 times
eaderigt
Post by eaderigt »
hello Mike,
code has been running now for about 12 days without any crashes or shell updates.
that length it has never reached before I implemented you solution.
So that is cool.
In the case it would crash again - then I will go back and make alternations on your other suggestions.
Again - thanks
mikeysklar
Thank you for the update. 12 day and counting++.
