Are job postings allowed and M7 is no longer working
- NLTSYP
Last night I was able to see the Metro M7 under file explorer on windows 10. I was using Circuit python and Mu. Now this morning it is no longer being found by Mu or file explorer. I am practically brand new to all of this and am lost. I have no idea what is wrong or how to even troubleshoot the device.
- goes out completely
- 3.JPG (60.66 KiB) Viewed 176 times
- close up
- 4.JPG (23.56 KiB) Viewed 176 times
- file explorer
- 5.JPG (37.87 KiB) Viewed 176 times
- NLTSYP
Re: Are job postings allowed and M7 is no longer working
first picture and 2nd picture didnt post for some reason.
- Franklin97355
Have you tried it without anything connected? Take a look at this and see if it helps.
- NLTSYP
@Franklin
I did try that before and nothing changed. But I decided to try switching to a different USB port on my computer and it worked then. This time I did start by having the NFC reader removed. My guess was that the usb port previously being used was not seated correctly? I am not sure.
Anyways it is now able to read the NFC card that was included, now I just need to find out how to reprogram a NTAG 213 to open a URl.
- NLTSYP
Follow up about the USb port on the PC...
I reconnected the M7 to the same USB port and it was not showing up like before, so I wiggled the connector that was attached to the PC and it showed up then.
So in conclusion it was the port on the PC that was causing the problem.
- Franklin97355
Great, now, what is your question on job posting?
- adafruit_support
here is the latest update and what we're doing as we upgrade/make some changes with the jobs board!
https://youtu.be/oYpkW53q3PU?t=1137
