I don't think it's possible to change the hardware SPI configuration and since the hardware SPI pins are already occupied by an LCD display, I can't access them.
Is there any way to fix the software SPI problem?
ADXL374 SPI Connection does not work as suspected
- jodu
Re: ADXL374 SPI Connection does not work as suspected
The whole point of SPI is that it is a bus. It is designed for multiple devices to share the same MISO, MOSI and SCK pins. You just need a unique CS pin for each one. The software driver will pull the CS pin LOW for the specific device it is wants to communicate with.the hardware SPI pins are already occupied by an LCD display
