Hi.
I have found this old board and tried to make it work.
the wifi firmware checked shows and old version and that it needs to be upgraded, i have uploaded the FirmwareUpdater code to the board with the line:`WiFi.setPins(8,7,4,2);` as instructed by the portal (adafruit).
the flash was successful, the serial monitor is turned off, however when opening the wifi101 firmware updater i don't seem to be able to find my board, the select box is empty. in the arduino ide the /dev/ttyUSB0 still appears and identifies my board correctly, but the firmware updater does not seem to discover my board.
It's arduino ide 2.0.4 , not java anymore and electron\react\js\ts in general is not my cup of tea and the code doesn't make a whole lot sense to me.
Any extra config i need to set up for this to work ? for the wifi firmware updater to recognize my board ?
cannot upgrade ATWINC1500 module on adafruit samd21 m0 with ATWINC1500
- eyalgal
- mikeysklar
Re: cannot upgrade ATWINC1500 module on adafruit samd21 m0 with ATWINC1500
Since this is an older board I'd try this with the 1.8.19 Legacy Arduino IDE.
