I am new to the product and I would like to access ADC measurements upon request via the USB interface on the Metro Mini V2 board. I was imagining that the way to do this would be to find a DLL (windows) that would have some C functions to do this. I was then going to call the c functions using C-types in python.
Is this a reasonable solution, or are there better ideas for doing this? If so, where could I find such a DLL?
Order: 3028801-3112350439
Python interface for Metro Mini V2 USB
- mikeysklar
Re: Python interface for Metro Mini V2 USB
Your approach to access the ADCs via Windows would be quite unorthodox.
Normally you would open up a serial connection via the USB interface and access the ADC values by printing them to the serial console from the Arduino code running on the chip.
- pm_circuit
Thank you very much for your reply!
I figured that my first stab at the solution would be a little off the wall, but threw it out there anyway. Are there any examples on opening a serial connection via the USB interface for Metro Mini V2? Could examples for an Arduino UNI be equally applicable?
- mikeysklar
Pretty much all example code sends data and status information over serial. This one will probably interest you the most from the Arduino IDE.
File --> Examples --> Basics --> Read Analog Voltage
ReadAnalogVoltage
Reads an analog input on pin 0, converts it to voltage, and prints the result to the Serial Monitor.
Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
https://www.arduino.cc/en/Tutorial/BuiltInExamples/ReadAnalogVoltage
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
Serial.begin(9600);
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
